richard lamare
hi to every one  i have a question when i was running my server with no emby premier i connect devices directly with pin number at https://emby.media/pin.html
now i have emby premier and i need to put the pin number and then connect manually how do i fix these iwant the direct connection only using pin
thanks in advance
samuelqwe
Go to the user settings and make sure your profile has an Emby Connect username or email entered. Without Emby Connect, that web page has no idea what to do with your pin.
  • Like 1
