lepitismak 1 Posted December 26, 2018 Posted December 26, 2018 1) I noticed that approximately every 24h the server consumes the memory of the machine totally (I am currently 32gb on a dedicated server). to solve this problem? 2) I'm using EmbyCon and constantly the movie folders and / or series are empty. In some cases errors appear. Examples: URL error: Internal Server Error. Connection Error timed out
Luke 42216 Posted December 26, 2018 Posted December 26, 2018 Hi there, can you please attach the Emby Server log? Thanks !
lepitismak 1 Posted December 26, 2018 Author Posted December 26, 2018 this happen only on movies lib (have 1856 movies) if i open a series open normal and fast if i change exibition pages for 100 (per page), i cant move to second page on embycon. any help?
Luke 42216 Posted December 26, 2018 Posted December 26, 2018 Can you attach the log to this posting? I don't really trust that website. Thanks.
Luke 42216 Posted December 26, 2018 Posted December 26, 2018 great, thanks. And yes, there are some really slow responses in this log. This should perform much better with the upcoming 3.6 release of Emby Server. Thanks.
lepitismak 1 Posted December 26, 2018 Author Posted December 26, 2018 When will this release be released? And in the meantime, what do I do?
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 great, thanks. And yes, there are some really slow responses in this log. This should perform much better with the upcoming 3.6 release of Emby Server. Thanks. I also have a problem with security measures for remote access. All options for forcing remote connections to use HTTPS do not work. Both HTTP and HTTPS are mapped to the extranet through unup, and HTTP ports can be accessed through remote addresses, and successfully logged in. Configuration that forcing remote connections to use HTTPS does not work。
Happy2Play 9806 Posted December 27, 2018 Posted December 27, 2018 I also have a problem with security measures for remote access. All options for forcing remote connections to use HTTPS do not work. Both HTTP and HTTPS are mapped to the extranet through unup, and HTTP ports can be accessed through remote addresses, and successfully logged in. Configuration that forcing remote connections to use HTTPS does not work。 It works if you port forward instead of UPNP/port mapping, correct? To me there has never been security via UPNP.
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 It works if you port forward instead of UPNP/port mapping, correct? To me there has never been security via UPNP. I set up a secure connection mode for all remote connections, but the HTTP port was still mapped to UPnP,This is not the result I want, the correct result is that the HTTP port will not be mapped to UPnP
Happy2Play 9806 Posted December 27, 2018 Posted December 27, 2018 (edited) I set up a secure connection mode for all remote connections, but the HTTP port was still mapped to UPnP,This is not the result I want, the correct result is that the HTTP port will not be mapped to UPnP But http port is broadcasting upnp on your local network and your Router is allowing that port to be accessible from the WAN. This is why UPNP really has no security, UPNP is a all or nothing protocal, it has nothing to do with Emby it is the protocol itself. Disabling UPNP resolves this issue, correct. Edited December 27, 2018 by Happy2Play
Luke 42216 Posted December 27, 2018 Posted December 27, 2018 I also have a problem with security measures for remote access. All options for forcing remote connections to use HTTPS do not work. Both HTTP and HTTPS are mapped to the extranet through unup, and HTTP ports can be accessed through remote addresses, and successfully logged in. Configuration that forcing remote connections to use HTTPS does not work。 Have you setup HTTPS with an SSL certificate?
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 Have you setup HTTPS with an SSL certificate? Yes, I installed the SSL certificate
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 But http port is broadcasting upnp on your local network and your Router is allowing that port to be accessible from the WAN. This is why UPNP really has no security, UPNP is a all or nothing protocal, it has nothing to do with Emby it is the protocol itself. Disabling UPNP resolves this issue, correct. When the secure connection mode is set to be required for all remote connections, remote connections should only use HTTPS instead of http. The solution is to close the network mapping for only http ports, not all of them.
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 Have you setup HTTPS with an SSL certificate? I mean: in the case that security mode is set to remote connections, HTTP ports should not be accessed by the public network, only HTTPS ports, or only open HTTPS ports. Or HTTP ports are not mapped by UPnP
Luke 42216 Posted December 27, 2018 Posted December 27, 2018 I mean: in the case that security mode is set to remote connections, HTTP ports should not be accessed by the public network, only HTTPS ports, or only open HTTPS ports. Or HTTP ports are not mapped by UPnP I understand, but you have to first setup SSL before you can use the HTTPS port. Did you do that?
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 (edited) I understand, but you have to first setup SSL before you can use the HTTPS port. Did you do that? I've configured SSL correctly and can access it properly. my concern is why HTTP ports can be accessed on the public network. Edited December 27, 2018 by juebanlin
Luke 42216 Posted December 27, 2018 Posted December 27, 2018 You need to set the secure connections mode to required. Have you done that? If you've done that and you think you're still seeing connections over HTTP, then please go over an example and attach the information requested in how to report a problem. Thanks !
juebanlin 1 Posted December 27, 2018 Posted December 27, 2018 You need to set the secure connections mode to required. Have you done that? If you've done that and you think you're still seeing connections over HTTP, then please go over an example and attach the information requested in how to report a problem. Thanks ! This problem exists in version 3.5, and then I don't have it in version 3.6.
Happy2Play 9806 Posted December 27, 2018 Posted December 27, 2018 (edited) I've configured SSL correctly and can access it properly. my concern is why HTTP ports can be accessed on the public network. How are you connecting to your server? There is currently no redirect for http://app.emby.media. I don't use UPNP and entering http://servername.com:8096 redirects me to https://servername.com:8920. Edited December 27, 2018 by Happy2Play
lepitismak 1 Posted December 27, 2018 Author Posted December 27, 2018 how i can install 3.6 server version? please. i need this fix
Luke 42216 Posted December 27, 2018 Posted December 27, 2018 Have you explored the download page of our website for instructions on beta releases? thanks.
lepitismak 1 Posted December 27, 2018 Author Posted December 27, 2018 my problem was the one reported at the beginning of the topic with excessive memory usage. with this version the problem is solved? if yes, is it enough that I overlap the installation? my library and users will keep up?
Luke 42216 Posted December 27, 2018 Posted December 27, 2018 It's a beta release, so you would only want to install it to participate in testing. You can learn more by checking out the Testing Area of the community: https://emby.media/community/index.php?/forum/102-emby-server/ Thanks.
