just-to-bad 2 Posted December 26, 2018 Posted December 26, 2018 Just made the switch to emby from Plex. Live Tv guide was free and pretty much plug&play with plex with hdhomerun quadro. installed emby Version 3.5.3.0 and could get a guide without http://www.schedulesdirect.org/ trial. Even then, guide isn't complete. There's got to be a better way ? thanks for helping out.
arche 177 Posted December 26, 2018 Posted December 26, 2018 Did you read about the new guide coming? https://emby.media/community/index.php?/topic/65984-exciting-additions-coming-soon-in-emby-server-36/ It's in beta at the moment (which you are free to try if you'd like, just remember, it's a beta version of emby). 1
Luke 42245 Posted December 26, 2018 Posted December 26, 2018 What about the guide is not complete? Can you go over an example? Thanks !
just-to-bad 2 Posted December 26, 2018 Author Posted December 26, 2018 (edited) ''You'll simply enter your zip code into Emby, select your channel lineup, and we'll handle retrieving your guide data''? Where in server manager do I find this option ? Edited December 26, 2018 by just-to-bad
arche 177 Posted December 26, 2018 Posted December 26, 2018 In the admin dashboard, go to the Live TV option, click the plus sign. Follow the prompts from there.
just-to-bad 2 Posted December 26, 2018 Author Posted December 26, 2018 In the admin dashboard, go to the Live TV option, click the plus sign. Follow the prompts from there. TV Guide Data Providers I have schedules direct, Xml tv and other
ebr 16337 Posted December 26, 2018 Posted December 26, 2018 Hi. Did you install the beta of 3.6? Emby guide data is a new feature in that upcoming version. Thanks.
just-to-bad 2 Posted December 26, 2018 Author Posted December 26, 2018 Thanks Admin. Problem Solved ! fully fonctionnal guide. How is it possible after upgrading to 3.6 that when I access http://192.168.0.x:8096/web/index.html#!/dashboard.htmlfrom another lan device, version is still is 3.5.x ?
Luke 42245 Posted December 26, 2018 Posted December 26, 2018 Can you try refreshing the browser? it probably still has 3.5 assets loaded. Thanks.
just-to-bad 2 Posted December 27, 2018 Author Posted December 27, 2018 Can you try refreshing the browser? it probably still has 3.5 assets loaded. Thanks. Thank you Luke. Problem was I was running Emby from freenas and windows at the same time. Everything works fine, great app !
