mix123 1 Posted December 25, 2018 Posted December 25, 2018 So I have all my channels. They work. I add the guide. It shows the channels and what's on correctly. But when I go to one of them it says no stream available and it just sits at retrieving. If I go to a channel that has no guide info it works fine. If I remove guide all channels work fine. What could issue be?
Luke 42242 Posted December 25, 2018 Posted December 25, 2018 Hi, are you able to play from the emby web app? Thanks.
Luke 42242 Posted December 26, 2018 Posted December 26, 2018 Ok, let's look at an example. Please attach the information requested in how to report a problem. thanks !
mix123 1 Posted December 29, 2018 Author Posted December 29, 2018 I restarted the server and it fixed it . Next issue. The guide is off the screen on the left side. The channel numbers are cut off. The rest of the app isn't like this. Also. Is there a way to go directly to a channel with no guide info. It won't allow me to select any channel that has no guide information.
Luke 42242 Posted December 30, 2018 Posted December 30, 2018 Yes the channels tab under the live TV section will let you do that. Please us know if this helps. Thanks.
ebr 16335 Posted January 1, 2019 Posted January 1, 2019 Next issue. The guide is off the screen on the left side. The channel numbers are cut off. The rest of the app isn't like this. Sounds like the display needs an overscan adjustment.
