Rominator 7 Posted April 23, 2014 Posted April 23, 2014 Finaly making the switch to MB3. I realy love it so far, and while i cofiguring the server i came across a thing that i want to ask. I have all my metadata and images localy saved, not downloading. My Bluray movies have a folder.jpg with 760x890, bluray cover aspect ratio. Coverart is configured to use the original aspect ratio. In the image you can see the the images only compressed in one libary view. i would really appreciate help to fix this
ebr 16344 Posted April 23, 2014 Posted April 23, 2014 I don't see any of the same actual movies in both screenshots so I can't be sure if it is the source image or just the view that is distorting. I suspect it is just the view but need to see the same actual items to get a better idea.
ebr 16344 Posted April 23, 2014 Posted April 23, 2014 Wait, I just spotted one. That confirms that it is probably just the view in the web client distorting the images for some reason. What do they look like in MBT or MBC?
Rominator 7 Posted April 23, 2014 Author Posted April 23, 2014 Havent installed MBC yet, i get back to you when i have it running.
Rominator 7 Posted April 25, 2014 Author Posted April 25, 2014 Installed MBC today. From what i see everything is ok, no disorting Images. So its only the web client that disorting the Images.
ebr 16344 Posted April 25, 2014 Posted April 25, 2014 Okay, it may have to do with the first two images that are showing in that list. The web client may be looking at the first image to determine the shape it should use. So, if the first one is radically different from the others that could throw it off.
