Charlie117 59 Posted January 9, 2020 Author Posted January 9, 2020 (edited) Ok, I'm the sole person Who else in this thread is supporting your controversial opinion then? Please do quote them. It's great that you were able to help certain users on this forum with issues that were resolved by forcing a transcode to AC-3 384 kbps. But that doesn't mean 640 kbps isn't generally supported. Calling this suggestion a bad idea just because you were proven wrong is seriously petty though. Edited January 9, 2020 by Charlie117
Guest asrequested Posted January 9, 2020 Posted January 9, 2020 I'm not wrong. Less and less devices have an optical port. It's an antiquated standard. Just because at the pinnacle, it's possible, how many manufacturers will actually invest in the later standards when HDMI is ubiquitous? Very few. So what that means is that most optical solutions provided in the real world, will be crap. Which translates to more emby users having playback issues. You really think going backwards in tech is the way forward? I don't even have single device that now has an optical port. Nvidia Shield dumped it long ago. Some of the crap Chinese stuff has it. TVs have an optical output, but again how many have the newer standard. Not very many. And even if they did, the OS would need to recognize it and take a gamble that what's on the other end, also supports it. This spells nothing but problems.
Jdiesel 1435 Posted January 9, 2020 Posted January 9, 2020 Optical out from a TV to a soundbar is still extremely common especially for low end market.
Guest asrequested Posted January 10, 2020 Posted January 10, 2020 Optical out from a TV to a soundbar is still extremely common especially for low end market. Yes it is, and how many times have we seen on here people reporting audio problems because they are using optical? It's not like HDMI where it reports it capabilities. It's spin the wheel and see if it works. And if it doesn't, there's loss of audio, either a few channels or the whole thing.
Charlie117 59 Posted January 10, 2020 Author Posted January 10, 2020 (edited) It's an antiquated standard. Well, at least we agree on that. My original request was for an option to select 640 kbps instead of the default 384 kbps. That really shouldn't be an issue for anyone, because again 640 kbps is completely supported by the standard, but for those rare cases that it does cause problems, people can just revert to the default low bitrate 384 kbps. Win-win for everybody. Interestingly enough, these people with the aforementioned issues with 640 kbps should not be able to watch DVDs, Blu-rays, Netflix, Amazon Prime, Disney+ etc. because they all use either a DD+ 5.1 at even higher bitrates that get automatically converted to DD 5.1 640 kbps or they get a DD 5.1 640 kbps natively. By your reasoning, DTS 5.1 core 1509 shouldn't be supported at all. I wonder why I am not reading a ton of issues with all this... probably because it isn't an issue Edited January 10, 2020 by Charlie117 1
zeroprobe 6 Posted April 12, 2020 Posted April 12, 2020 (edited) I echo the request. Custom bitrate would be a great feature. Or a convert to dd+ Edited April 12, 2020 by zeroprobe 3
FrostByte 5454 Posted April 12, 2020 Posted April 12, 2020 +1 for custom bitrate and choosing which audio format. I like DD+ for TV. This should apply to music also though. The Shield seems to convert lossless WMA to 128bit AAC. I would prefer mp3 and something a little higher than 128 bits 1
zeroprobe 6 Posted April 12, 2020 Posted April 12, 2020 (edited) I've managed to mod the lib where the audio bitrate is. It won't be ideal to do every update. So now my movies with DTS get transcoded to 640K AC3. The file in question. Emby.Server.MediaEncoding.dll TranscodingCommandBuilder TranscodingCommandBuilderLegacy I've done it for the Synology version. >>>>> Legacy Command /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ss 00:07:48.000 -f matroska -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.1.100%2Fmedia_external.mkv"-threads 0 -map 0:0 -map 0:1 -c:v:0 copy -copyts -vsync -1 -codec:a:0 ac3 -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 640000 -ar:a:0 48000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -segment_time_delta -468 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 78 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8_%d.ts">>>>> Actual Command/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -loglevel +timing -y -print_graphs_file /var/packages/EmbyServer/target/var/logs/ffmpeg-remux-483e1018-f98a-4d2e-8a2b-d0f63c61bafc_1graph.txt -copyts -start_at_zero -f matroska,webm -ss 00:07:48.000 -c:v:0 hevc -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.1.100%2Fmedia_external%2F.mkv"-map 0:0 -map 0:1 -sn -c:v:0 copy -c:a:0 ac3 -ab:a:0 640000 -ar:a:0 48000 -ac:a:0 6 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/6E62D8.m3u8 -segment_list_type m3u8 -segment_time 6 -segment_time_delta -00:07:48.000 -segment_start_number 78 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8_%d.ts" Edited April 12, 2020 by zeroprobe 1
zeroprobe 6 Posted April 15, 2020 Posted April 15, 2020 (edited) If anyone wants to try this mod until something official comes. Patch seems to find ok for x86/x64 variants Windows / Synology tested, if the below search is found it should be fine. Just find a Hex editor that supports a wildcard search for example Hex Workshop or Winhex. Find and open Emby.Server.MediaEncoding.dll On Synology, you need to copy to your NAS share location to edit it and put back after editing. In Synology this is located below, your volume name may be different. /volume1/@appstore/EmbyServer/releases/4.5.0.5-beta/ Telnet / SSH into Synology sudo su ls -l / Find volume name cd /volume1/@appstore/EmbyServer/4*/ cp Emby.Server.MediaEncoding.dll /volume1/MyNASShare (Your share name will be what you called it) Open in Hex Workshop / Winhex. Hex Workshop: using as a wildcard ?? Search - 120A28??01000A2000EE020028??02000A289000000A2B18120A120A28??01000A2000DC050028??02000A Replace - 000000000000002000C409000000000000289000000A2B18120A000000000000002000C409000000000000 WinHex : using as a wildcard 58 Search - 120A285801000A2000EE0200285802000A289000000A2B18120A120A285801000A2000DC0500285802000A Replace - 000000000000002000C409000000000000289000000A2B18120A000000000000002000C409000000000000 Copy Emby.Server.MediaEncoding.dll back to original location e.g Synology cd /volume1/MyNASShare (Your share name will be what you called it) cp -i Emby.Server.MediaEncoding.dll /volume1/@appstore/EmbyServer/4*/ Should be prompted y to overwrite. Restart the Emby Server, in Synology - Package Center > Installed > Stop | Start The remux log should now say, I've copied a transcoded TS and checked verified also. 09:45:13.064 Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1, fltp (24 bit), 640 kb/s (default) Have fun Edited April 15, 2020 by zeroprobe 2
zeroprobe 6 Posted April 16, 2020 Posted April 16, 2020 (edited) nm Edited April 16, 2020 by zeroprobe
cybergrimes 93 Posted April 21, 2020 Posted April 21, 2020 (edited) Me too for this as a configurable option. Edited April 21, 2020 by cybergrimes
Charlie117 59 Posted August 31, 2020 Author Posted August 31, 2020 On 12/04/2020 at 14:52, zeroprobe said: I echo the request. Custom bitrate would be a great feature. Or a convert to dd+ Dolby Digital Plus would be even better, especially now that ffmpeg supports it. DD+ is also backwards compatible with DD only devices:Is Dolby Digital Plus content backward-compatible? Because Dolby Digital Plus is built on core Dolby Digital technologies, content that is encoded with Dolby Digital Plus is fully compatible with the millions of existing home theaters and playback systems worldwide equipped for Dolby Digital playback. Dolby Digital Plus soundtracks are easily converted to a 640 kbps Dolby Digital signal without decoding and reencoding, for output via S/PDIF. The 640 kbps bit rate, which is higher than the standard 448 kbps used on DVDs, is fully compatible with all existing Dolby Digital decoding products such as A/V receivers, and can provide higher-than-DVD quality from Dolby Digital Plus soundtracks when played back through existing systems.https://www.dolby.com/uploadedFiles/Assets/US/Doc/Professional/dolby-digital-plus-faq.pdf 1
staticmotion 4 Posted November 30, 2020 Posted November 30, 2020 (edited) I'll add my vote to this feature - both configurable bitrate and format would be appreciated. I am using a couple of Samsung TVs which don't support DTS; I'd prefer Emby server to transcode to PCM rather than relatively low bitrate AC3 - especially for the 7.1 soundtracks! thanks Edited November 30, 2020 by staticmotion typo
FrostByte 5454 Posted December 3, 2020 Posted December 3, 2020 On 11/30/2020 at 2:32 PM, staticmotion said: I'll add my vote to this feature - both configurable bitrate and format would be appreciated. I am using a couple of Samsung TVs which don't support DTS; I'd prefer Emby server to transcode to PCM rather than relatively low bitrate AC3 - especially for the 7.1 soundtracks! thanks Samsung TVs (and most others) only support PCM 2.0 though. I would much rather have DD 5.1 at 640 kbps or DD+ 5.1 at 1536 kbps
alphanet 0 Posted March 10, 2021 Posted March 10, 2021 On 4/12/2020 at 5:07 PM, zeroprobe said: I've managed to mod the lib where the audio bitrate is. It won't be ideal to do every update. So now my movies with DTS get transcoded to 640K AC3. The file in question. Emby.Server.MediaEncoding.dll TranscodingCommandBuilder TranscodingCommandBuilderLegacy I've done it for the Synology version. >>>>> Legacy Command /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ss 00:07:48.000 -f matroska -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.1.100%2Fmedia_external.mkv"-threads 0 -map 0:0 -map 0:1 -c:v:0 copy -copyts -vsync -1 -codec:a:0 ac3 -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 640000 -ar:a:0 48000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -segment_time_delta -468 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 78 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8_%d.ts" >>>>> Actual Command /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -loglevel +timing -y -print_graphs_file /var/packages/EmbyServer/target/var/logs/ffmpeg-remux-483e1018-f98a-4d2e-8a2b-d0f63c61bafc_1graph.txt -copyts -start_at_zero -f matroska,webm -ss 00:07:48.000 -c:v:0 hevc -i "http://127.0.0.1:8096/Items/File?Id=smb%3A%2F%2F192.168.1.100%2Fmedia_external%2F.mkv"-map 0:0 -map 0:1 -sn -c:v:0 copy -c:a:0 ac3 -ab:a:0 640000 -ar:a:0 48000 -ac:a:0 6 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/6E62D8.m3u8 -segment_list_type m3u8 -segment_time 6 -segment_time_delta -00:07:48.000 -segment_start_number 78 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/packages/EmbyServer/target/var/transcoding-temp/6E62D8_%d.ts" I've tried to do this, but I don't know exactly how to do it, I'm using DnSpy to edit the Emby.Server.MediaEncoding.dll file. Please need help
alphanet 0 Posted May 14, 2021 Posted May 14, 2021 Please, we need the option for choose the bitrate for DTS transcoding
MakiXx 1 Posted August 22, 2021 Posted August 22, 2021 I'd like this too. I would like all my transcoding to ac3 to be 640 kbps. I opened a separate thread just to figure out what was going on.
MakiXx 1 Posted August 23, 2021 Posted August 23, 2021 (edited) I came up with my own solution today that will force all Dolby Digital (ac3) transcoding to 640 kbps. I tried converting it to Dolby Digital Plus (eac3) but quickly found out that ffmpeg unfortunately doesn't have a very good DD+ encoder. It's something like 500$ a year per machine for Dolby's official encoder I think. Ergh gross. My solution involves replacing ffmpeg with a C program that modifies the arguments and then runs ffmpeg. I've built it on top of the Docker image so that I don't have to replace my host's ffmpeg binary or anything. If using docker-compose.yml Make a folder named build and place the two attached files below into it Replace image: emby/embyserver:latest with build: ./build When running docker-compose up -d, it will automatically build and start To force a build (for new Emby versions) run docker-compose build and up -d If you're not using Docker (not recommended unless its in a VM or on an individual machine) Find ffmpeg (which ffmpeg) and rename to _ffmpeg. It might be in /usr/bin or /bin Download ffmpeg.c and update line 42 with your ffmpeg path Run gcc -static -O3 -o ffmpeg ffmpeg.c Move newly compiled ffmpeg binary to original ffmpeg path Just to explain what the C program does, it looks for arguments -c:a:? ac3 then replaces -ab:a:? ?????? with -ab:a:? 640000 I hope this helps someone! I'm super happy with my solution. Dockerfile ffmpeg.c Edited August 25, 2021 by MakiXx
MakiXx 1 Posted August 23, 2021 Posted August 23, 2021 On 5/14/2021 at 6:34 AM, alphanet said: Please, we need the option for choose the bitrate for DTS transcoding For the people above who'd like to transcode to DTS instead, I could modify the C file to replace DD with DTS and a forced bitrate. Then the "Convert Unsupported Audio to Dolby Digital" settings would convert to DTS instead haha. My sound system only supports Dolby and PCM.
staticmotion 4 Posted August 24, 2021 Posted August 24, 2021 On 8/23/2021 at 7:00 PM, MakiXx said: For the people above who'd like to transcode to DTS instead, I could modify the C file to replace DD with DTS and a forced bitrate. Then the "Convert Unsupported Audio to Dolby Digital" settings would convert to DTS instead haha. My sound system only supports Dolby and PCM. To be honest a Windows version would be more useful! Encoding to DTS isn't a good idea as most of the people are having to re-encode because their TV doesn't accept DTS.
MakiXx 1 Posted August 25, 2021 Posted August 25, 2021 6 hours ago, staticmotion said: To be honest a Windows version would be more useful! Encoding to DTS isn't a good idea as most of the people are having to re-encode because their TV doesn't accept DTS. I've made a GitHub repo with instructions and Windows/Linux builds of my wrapper through GitHub actions so that it's verifiably legit. Let me know if you need help. https://github.com/makitsune/emby-custom-ac3-bitrate 1
cwills75 14 Posted March 25, 2022 Posted March 25, 2022 (edited) On 8/24/2021 at 7:51 PM, MakiXx said: I've made a GitHub repo with instructions and Windows/Linux builds of my wrapper through GitHub actions so that it's verifiably legit. Let me know if you need help. https://github.com/makitsune/emby-custom-ac3-bitrate Any idea how to make this work with Unraid docker version of Emby? I tried editing the hex values from a post above, but it seems some of them have changed since that post as I can't find the same string. I'm hoping your method will work, but have no idea what to do with the github files. Edited March 25, 2022 by cwills75
cwills75 14 Posted March 25, 2022 Posted March 25, 2022 On 1/7/2020 at 10:25 AM, Luke said: Thanks for the feedback. More options are possible for the future. Any update on allowing a custom/higher bitrate for transcoded audio. I wasn't even aware this was an issue until recently, but I have a few clients on Apple TV with receivers that are stuck playing AC3 384kb/s with any DTS files. I was aware the Apple TV doesn't bitstream DTS/DTS-HD MA/DTS-X, but was never aware of the low bitrate until seeing this post and looking in the log files. Even the streaming info when the file is being played doesn't show audio transcoding going on. It says direct streaming, which isn't really accurate. adam1.txt
