pflynn001 1 Posted December 21, 2018 Posted December 21, 2018 I can’t connect to the server I have running on my Nvidia shield using firetv, fire stick, or iPhone. The server shows up, but when I try to connect it is unavailable. I have no problem connecting using my Windows PC.
pflynn001 1 Posted December 22, 2018 Author Posted December 22, 2018 (edited) Figured it out. Was using loop back ip. Edited December 22, 2018 by pflynn001 1
Luke 42237 Posted January 11, 2019 Posted January 11, 2019 I can't find server please help Hi, you need to setup your own Emby Server. Have you done that?
Luke 42237 Posted January 11, 2019 Posted January 11, 2019 Where must I go send link Please check out our quick start guide: https://github.com/MediaBrowser/Wiki/wiki/Quick-start Thanks.
