FrostByte 5453 Posted October 6, 2025 Posted October 6, 2025 As an alternative you can use R3S3t9999's script to create an EAC3 5.1 or EAC3 7.1 compatibility track. https://github.com/R3S3t9999/DoVi_Scripts Additionally, you will need to also get the external tool EAE in order to create EAC3 7.1 tracks. How to set it up is all in the link above. After setting up it's basically just a drag and drop script. All my scripts are based on R3S3t9999's code. 1
