siddhartha 11 Posted December 21, 2018 Posted December 21, 2018 (edited) Newer Samsung TVs won't support DTS passthrough on MKV files. The following Bash script will convert the file to EAC3 if it's either TrueHD, DTS, FLAC, or has PGS subtitles. This assumes you have ffmpeg installed. It can be modified to work with your favourite torrent client to be an automated process. If you are using it as an automated script, it's worth while to sleep 10 before checking for file locks. Note that there is a small bug that will happen if the a TrueHD/DTS/FLAC audio stream of a file is at a higher index than a PGS subtitle stream. This happens because of the way ffmpeg maps input streams and references output streams. If you run into this bug, the solution is to simply run the script again on the output file. Enjoy. Windows version here. #!/bin/bash file=$1 tmp=temp.mkv # Check if the file is open lsof | grep "${file}" >/dev/null 2>&1 || ( # Check if the file is encoded with DTS or TrueHD or PGS probe=$(ffprobe -i "${file}" 2>&1) && ( echo "${probe}" | grep -Eq "Audio: (truehd|dts)" || echo "${probe}" | grep -Eq "Subtitle: pgs" ) && # Create a subtitle stream that exludes all PGS streams substream=$(echo "${probe}" | grep -E "Subtitle: pgs" | sed -E 's/.*(0:[0-9]+).*/-map -0:\1/' | tr '\n' ' ') && echo "substream=${substream}" && # Only convert DTS, TrueHD, and FLAC streams to EAC3 acstream=$(echo "${probe}" | grep -E "Audio: (truehd|dts|flac)" | sed -E 's/.*0:([0-9]+).*/-c:\1 eac3 -ac:\1 6 -b:\1 1536k/' | tr '\n' ' ') && echo "acstream=${acstream}" && # Convert! ffmpeg -i "${file}" -map 0 ${substream} -c:a copy ${acstream} -c:v copy -c:s copy -f matroska temp.mkv && # Replace the original mkv with the newly converted file mv "${temp}" "${file}" ) Edited December 15, 2019 by siddhartha 2
holdestmade 11 Posted December 21, 2018 Posted December 21, 2018 This looks brilliant, thanks. Could you show how to use it with utorrent please ?
siddhartha 11 Posted June 20, 2019 Author Posted June 20, 2019 (edited) This looks brilliant, thanks. Could you show how to use it with utorrent please ? I don't use uTorrent, but I do use Deluge and Flexget. I run the script automatically on every completed download. For uTorrent, I believe there were flags passed to the batch file like %D %N which correspond to the directory and filename. I would check the documentation. If you're running Windows, the parameters for ffmpeg will likely be the same. The full version of my script is here: #!/bin/bash # Sort torrents using flexget and process with ffmpeg to MKV files for Direct Play on 2018+ Samsung TVs # Updated 2019.12.15 torrentid=$1 torrentname=$2 torrentpath=$3 moviespath=/srv/media/downloads/movies tvseriespath=/srv/media/downloads/tv incomingpath=/srv/media/downloads/incoming logfile=/var/lib/deluged/scripts/torsort.log tempsuffix=".EAC3REENC" log () { echo $(date '+%Y-%m-%d %H:%M:%S') $1 >>${logfile} } if [[ ${torrentpath} != ${moviespath} && ${torrentpath} != ${tvseriespath} ]]; then exit 0 fi # Sleep for a few seconds to free up any locks sleep 10 files=() while IFS= read -r -d $'\0'; do files+=("$REPLY") done < <(find "${torrentpath}" -name "*.mkv" -print0) for file in "${files[@]}"; do # Check if the file is open lsof | grep "${file}" >/dev/null 2>&1 || ( # Check if the file is encoded with DTS, TrueHD, FLAC, or PGS probe=$(ffprobe -i "${file}" 2>&1) && ( echo "${probe}" | grep -Eq "Audio: (truehd|dts|flac)" || echo "${probe}" | grep -Eq "Subtitle: pgs" ) && ( # Move the file to a temporary directory mv "${file}" "${incomingpath}" && log "mv '${file}' to '${incomingpath}'" # Create a subtitle stream that exludes all PGS streams substream=$(echo "${probe}" | grep -E "Subtitle: pgs" | sed -E 's/.*(0:[0-9]+).*/-map -0:\1/' | tr '\n' ' ') && log "substream='${substream}'" # Only convert TrueHD, DTS, and FLAC streams to EAC3 acstream=$(echo "${probe}" | grep -E "Audio: (truehd|dts|flac)" | sed -E 's/.*0:([0-9]+).*/-c:\1 eac3 -ac:\1 6 -b:\1 1536k/' | tr '\n' ' ') && log "acstream='${acstream}'" # Encode the audio as EAC3 to the original path # Use a temporary suffix so the open file isn't touched by flexget log "ffmpeg '${file}${tempsuffix}'" ffmpeg -i "${incomingpath}/$(basename "${file}")" -map 0 ${substream} -c:a copy ${acstream} -c:v copy -c:s copy -f matroska "${file}${tempsuffix}" && log "Cleaning up" # Remove the temporary file rm -f "${incomingpath}/$(basename "${file}")" && # Remove the temporary suffix mv "${file}${tempsuffix}" "${file}" ) ) done case "$torrentpath" in "$moviespath") /usr/local/bin/flexget -c /etc/flexget/config.yml execute --tasks sort_movies ;; "$tvseriespath") /usr/local/bin/flexget -c /etc/flexget/config.yml execute --tasks sort_tv_series ;; *) exit 0 ;; esacThe relevant part of my flexget config.yml is: tasks: sort_tv_series: no_entries_ok: yes parsing: series: guessit metainfo_series: yes disable: - seen - seen_info_hash template: tv_series series: settings: webrip+ 720p+: parse_only: yes filesystem: path: '{? filesystem.complete_tv ?}' regexp: '.*\.(avi|mkv|mp4)$' recursive: yes regexp: reject: - '^sample' - '.*-sample.*' - '.*\.sample$' require_field: series_name accept_all: yes move: to: '{? filesystem.series_path ?}' clean_source: 350 along: extensions: - sub - srt - idx subdirs: - subs - subtitles sort_movies: no_entries_ok: yes disable: - seen - seen_info_hash filesystem: path: '{? filesystem.complete_movies ?}' regexp: '.*\.(avi|mkv|mp4)$' recursive: yes regexp: reject: - '^sample' - '.*-sample.*' - '.*\.sample$' accept_all: yes move: to: '{? filesystem.movies_path ?}' clean_source: 350 along: extensions: - sub - srt - idx subdirs: - subs - subtitles Edited December 15, 2019 by siddhartha
holdestmade 11 Posted June 20, 2019 Posted June 20, 2019 (edited) Thanks for the reply, the new emby update plays DTS on the fly now so don't need to do any post processing Cheers Edited June 20, 2019 by holdestmade
siddhartha 11 Posted November 14, 2019 Author Posted November 14, 2019 I still much prefer to have Emby direct play MKV files since transcoding puts unnecessary load on the CPU. I've updated the script to copy over any non-PGS subtitle tracks (as PGS subtitles seem to be an issue for Samsung TVs) and the script now copies over any playable audio tracks, only converting DTS and TrueHD audio. It's been perfect for the year I've been using it. 1
FrostByte 5452 Posted November 14, 2019 Posted November 14, 2019 I still much prefer to have Emby direct play MKV files since transcoding puts unnecessary load on the CPU. I've updated the script to copy over any non-PGS subtitle tracks (as PGS subtitles seem to be an issue for Samsung TVs) and the script now copies over any playable audio tracks, only converting DTS and TrueHD audio. It's been perfect for the year I've been using it. Agree, plus the higher bitrate DD+ sounds a lot better (as long as your soundbar supports it) than DD I think
iceman81 1 Posted December 9, 2019 Posted December 9, 2019 @@siddhartha Thank You for the effort of creating this script. Would it be possible for you to make similar one but for Windows ffmpeg?
siddhartha 11 Posted December 12, 2019 Author Posted December 12, 2019 @@siddhartha Thank You for the effort of creating this script. Would it be possible for you to make similar one but for Windows ffmpeg? I'm actually not that versed in PowerShell, but I'll take a look.
siddhartha 11 Posted December 14, 2019 Author Posted December 14, 2019 (edited) Okay, I think I have a working Windows version. You need to download ffmpeg.exe and ffprobe.exe and place them in the eac3conv folder. To use the script, just drag and drop an MKV file onto eac3conv.bat. eac3conv11.7z Edited December 15, 2019 by siddhartha 3
iceman81 1 Posted December 15, 2019 Posted December 15, 2019 Thanks for your effort. I have encountered this error: .\ffprobe.exe : The term '.\ffprobe.exe' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again. At C:\eac3conv\eac3conv.ps1:3 char:9 + $probe=(.\ffprobe.exe "$file" 2>&1) + ~~~~~~~~~~~~~ + CategoryInfo : ObjectNotFound: (.\ffprobe.exe:String) [], CommandNotFoundException + FullyQualifiedErrorId : CommandNotFoundException The same with grep.exe and next with ffmpeg.exe 1
siddhartha 11 Posted December 15, 2019 Author Posted December 15, 2019 (edited) Thanks for your effort. I have encountered this error: .\ffprobe.exe : The term '.\ffprobe.exe' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again. At C:\eac3conv\eac3conv.ps1:3 char:9 + $probe=(.\ffprobe.exe "$file" 2>&1) + ~~~~~~~~~~~~~ + CategoryInfo : ObjectNotFound: (.\ffprobe.exe:String) [], CommandNotFoundException + FullyQualifiedErrorId : CommandNotFoundException The same with grep.exe and next with ffmpeg.exe I've modified the attachment in the post to fix the issue. Thanks for the tip! (This happened if the source MKV was outside the eac3conv directory) Edited December 15, 2019 by siddhartha 3
iceman81 1 Posted December 15, 2019 Posted December 15, 2019 Now its working like a charm. Thank You very much.
fredosp87 0 Posted December 29, 2019 Posted December 29, 2019 hello, I find your script great it works super well, I would like to know how to make a waiting list of mkv file so that they convert to the following thanks I’m French and my English is limited sorry for the vocabulary
iceman81 1 Posted January 2, 2020 Posted January 2, 2020 hi @@siddhartha recently i've noticed that when movie filename have spaces in it the script gives an error. Thats not a big deal though to change the name temporary for conversion.
xzilvinas 0 Posted March 26, 2020 Posted March 26, 2020 (edited) Okay, I think I have a working Windows version. You need to download ffmpeg.exe and ffprobe.exe and place them in the eac3conv folder. To use the script, just drag and drop an MKV file onto eac3conv.bat. eac3conv11.7z This is awesome tool since i got useless samsung 4k tv that wont read dts, thanks very much. But there is one bug, there a problem when you drop a file that has spaces in the title or folder has spaces where the file is. S:\Downloads\Good: No such file or directory mv : Cannot find path 'S:\eac3conv\temp.mkv' because it does not exist. At S:\eac3conv\eac3conv.ps1:13 char:1 + mv temp.mkv ($path + '\' + $basename + '.eac3.mkv') + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : ObjectNotFound: (S:\eac3conv\temp.mkv:String) [Move-Item], ItemNotFoundException + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.MoveItemCommand PS S:\eac3conv> For example if the file name is Good Boys 2019 1080p Hybrid WEBRip DTS x264-RightSiZE.mkv and i drag and drop it on eac3conv.bat there is this error, but if i change all the spaces to dots(.), then all is fine, same apply to directory if folder where the file is also has spaces in name, it will give same error. Edited March 26, 2020 by xzilvinas
Synthetic 0 Posted May 12, 2020 Posted May 12, 2020 Hey sorry to drag up an old thread, works great thanks, however i'm wondering if it's possible to amend the windows script so rather than replace the DTS stream, it adds a second EAC3 stream? Thanks!
WINTEX 1 Posted August 24, 2020 Posted August 24, 2020 (edited) On 1/2/2020 at 9:24 AM, iceman81 said: i've noticed that when movie filename have spaces in it the script gives an error. On 3/27/2020 at 12:21 AM, xzilvinas said: there a problem when you drop a file that has spaces in the title or folder has spaces where the file is. @iceman81 @xzilvinas and to all others. To fix this bug with script not working properly with filenames with spaces just change in eac3conv.ps1 iex ".\ffmpeg.exe -i $file -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" to iex ".\ffmpeg.exe -i '$file' -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" The problem is solely because of the absence of single quotes. Best regards! Edited August 24, 2020 by WINTEX 1
rbjtech 5341 Posted October 13, 2020 Posted October 13, 2020 Nice script - an alternative to creating a new file, is to simply insert the eac3 track into the existing MKV. You need to remap a few tracks but essentially this is the syntax - "ffmpeg.exe" -i "input.mkv" -map 0:v -map 0:a:0 -map 0:a -c:v copy -c:a copy -c:a:0 eac3 -disposition:a:0 default -disposition:a:1 0 "output.mkv" It will mark the eac3 as the new default audio track, moving the previous audio track to 2nd in the drop down list. 1
xzilvinas 0 Posted January 13, 2021 Posted January 13, 2021 On 8/25/2020 at 12:55 AM, WINTEX said: @iceman81 @xzilvinas and to all others. To fix this bug with script not working properly with filenames with spaces just change in eac3conv.ps1 iex ".\ffmpeg.exe -i $file -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" to iex ".\ffmpeg.exe -i '$file' -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" The problem is solely because of the absence of single quotes. Best regards! thanks for help, But maybe you also know how to make batch? I like to convert like 10+ videos, how can i make this script convert whole folder? Or maybe someone else have suggestion?
gzeta72 0 Posted January 19, 2021 Posted January 19, 2021 On 8/24/2020 at 4:55 PM, WINTEX said: @iceman81 @xzilvinas and to all others. To fix this bug with script not working properly with filenames with spaces just change in eac3conv.ps1 iex ".\ffmpeg.exe -i $file -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" to iex ".\ffmpeg.exe -i '$file' -map 0$substream -c:a copy $acstream -c:v copy -c:s copy -f matroska temp.mkv" The problem is solely because of the absence of single quotes. Best regards! Wow. First of all, I don't really speak english, but this was a great solution for me. I just want to convert DTS / TrueHD to eAC3 and the only option I had was Handbrake (which does not allow direct copy function in video). With this script, ¡problem solved! Thanks a lot :)
mrprivate 0 Posted June 23, 2021 Posted June 23, 2021 On 1/13/2021 at 7:55 PM, xzilvinas said: thanks for help, But maybe you also know how to make batch? I like to convert like 10+ videos, how can i make this script convert whole folder? Or maybe someone else have suggestion? it could be nice to be able to batch convert
rbjtech 5341 Posted June 23, 2021 Posted June 23, 2021 (edited) A simple batch script below in red - just paste into a new notepad file called convert.bat. copy into the folder you wish to run it from - and all subfolders will be processed. if you wish to delete the original file - then just remove the 'rem' from the delete line, otherwise the original will be kept. Remember to change the path to ffmpeg. edit - note the script just uses the first audio track it finds to make the new eac3 audio track (and make it the default) - it does not apply any sort of logic or intelligence. edit 2 - eac3 bitrate is 256k - according to dolby themselves (see below) this is sufficient. (DTS (5.1) > EAC3) https://developer.dolby.com/technology/dolby-audio/dolby-digital-plus/ @echo off FOR /F "delims=" %%x in ('dir /a-s /b /s *.mkv') DO ( "<YOUR_EMBY_PATH_FFMPEG_LOCATION>ffmpeg.exe" -i "%%x" -map 0:v -map 0:a:0 -map 0:a -c:s copy -c:v copy -c:a copy -c:a:0 -b:a 256k eac3 -disposition:a:0 default -disposition:a:1 0 -f matroska "%%~dx%%~px%%~nx-EAC3.mkv" rem del /q "%%~dx%%~px%%~nx.mkv" ) Edited June 23, 2021 by rbjtech 1
xzilvinas 0 Posted September 8, 2025 Posted September 8, 2025 On 6/23/2021 at 8:26 PM, rbjtech said: A simple batch script below in red - just paste into a new notepad file called convert.bat. copy into the folder you wish to run it from - and all subfolders will be processed. if you wish to delete the original file - then just remove the 'rem' from the delete line, otherwise the original will be kept. Remember to change the path to ffmpeg. edit - note the script just uses the first audio track it finds to make the new eac3 audio track (and make it the default) - it does not apply any sort of logic or intelligence. edit 2 - eac3 bitrate is 256k - according to dolby themselves (see below) this is sufficient. (DTS (5.1) > EAC3) https://developer.dolby.com/technology/dolby-audio/dolby-digital-plus/ @echo off FOR /F "delims=" %%x in ('dir /a-s /b /s *.mkv') DO ( "<YOUR_EMBY_PATH_FFMPEG_LOCATION>ffmpeg.exe" -i "%%x" -map 0:v -map 0:a:0 -map 0:a -c:s copy -c:v copy -c:a copy -c:a:0 -b:a 256k eac3 -disposition:a:0 default -disposition:a:1 0 -f matroska "%%~dx%%~px%%~nx-EAC3.mkv" rem del /q "%%~dx%%~px%%~nx.mkv" ) getting this error: [AVFormatContext @ 00000171fa3a7b40] Unable to choose an output format for '256k'; use a standard extension for the filename or specify the format manually. [out#0 @ 00000171fa3a7200] Error initializing the muxer for 256k: Invalid argument Error opening output file 256k. Error opening output files: Invalid argument
rbjtech 5341 Posted September 8, 2025 Posted September 8, 2025 Hmm - 4 years is a long time - ffmpeg may have updated their syntax. I'll test it later on today ..
xzilvinas 0 Posted October 1, 2025 Posted October 1, 2025 On 9/8/2025 at 4:24 PM, rbjtech said: Hmm - 4 years is a long time - ffmpeg may have updated their syntax. I'll test it later on today .. have you had time to test it?
