GhostRider 49 Posted December 21, 2018 Posted December 21, 2018 Hi, Using MKV format, I have a set of three movies that need subtitles that Emby was not displaying any subtitle. Mediainfo showed no flag set default or forced against any subtitle. I then remuxed and set default and forced flags against the appropriate subtitle #4. Emby now plays with subtitle #1 not the forced #4 subtitle. User preferences are set to only forced subtitles. I had to maually select the forced subtitle track from the drop down menu. I am confused, any ideas why did Emby not pick up the forced subtitle track? As Emby remembers on per film basis how can I clear this to re test more? Can Emby have an option to show when a forced subtitle is present? E.g. show the CC icon in red rather than white?
Luke 42216 Posted December 21, 2018 Posted December 21, 2018 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
GhostRider 49 Posted December 21, 2018 Author Posted December 21, 2018 (edited) Thanks Luke for responding over the holiday period. I am migrating some films from DVD to blu ray so are replacing existing MKV files. Not sure if this is part of the problem. I have just completed another film, this time I set the flag to only forced (not default and forced). Copied this over and replaced the MKV file on the server, did a rescan and Emby picked up the forced flag OK. For the film that did not work I have since used the drop down menu to select the correct subtitle. Only way I can think to test this further is to get Emby to forget the per film setting for subtilte for this specific film. How can I do this? I could not see it in the NFO file. I can then post a debug log. p.s. would it be better to extract them as external subtitles? Does Emby support both i.e. MKV has track #6 marked forced and I have an external forced subtitle? Just thinking if external subtitles are better do I have to remux again and remove the internal forced flag or does Emby take the external as a priority? Edited December 21, 2018 by GhostRider
Luke 42216 Posted December 23, 2018 Posted December 23, 2018 I had to maually select the forced subtitle track from the drop down menu. I am confused, any ideas why did Emby not pick up the forced subtitle track? There are user preferences, but selections get remembered on a per-file basis, so this is what happened here. Please try this again with a new brand new video imported into your library. Thanks.
