Luke 42244 Posted January 4, 2019 Posted January 4, 2019 I don't recall the specifics but since this is vaders i added a workaround for this the other day to the beta server. So it is resolved for the next release. Thanks.
wulfeman6869 1 Posted January 4, 2019 Author Posted January 4, 2019 I don't recall the specifics but since this is vaders i added a workaround for this the other day to the beta server. So it is resolved for the next release. Thanks.What version of the release will have this work around?. I also have this issue now Sent from my SM-N950U using Tapatalk
Luke 42244 Posted January 5, 2019 Posted January 5, 2019 The next stable release of Emby Server. It is already in the beta channel. Thanks.
wulfeman6869 1 Posted January 5, 2019 Author Posted January 5, 2019 ok but im still not getting the guide for vaders
Luke 42244 Posted January 5, 2019 Posted January 5, 2019 then it might actually be invalid xml. have you seen the postings from other users where they mentioned that vaders xml currently has some issues?
wulfeman6869 1 Posted January 5, 2019 Author Posted January 5, 2019 Yes .. But the guide shows in the vader native app and apps the use m3u settings. Sent from my SM-N950U using Tapatalk
wulfeman6869 1 Posted January 5, 2019 Author Posted January 5, 2019 ill give it a couple more days and see if the issue is with vaders.
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 Have you tried validating the xml? https://www.xmlvalidation.com/
wulfeman6869 1 Posted January 6, 2019 Author Posted January 6, 2019 the file seems to be to big... it does not come back with any results.
rkirchhof 1 Posted January 6, 2019 Posted January 6, 2019 I had the same experiance. Looking for alternativs.
rkirchhof 1 Posted January 6, 2019 Posted January 6, 2019 This tool: https://onlinexmltools.com/validate-xml allowed me to upload a copy of the file from my desktop and reported NO errors.
rkirchhof 1 Posted January 6, 2019 Posted January 6, 2019 Ojay Perhaps I didn't wait long enough. BC When I tried again I got this: If only I could figure out where it is?
wulfeman6869 1 Posted January 6, 2019 Author Posted January 6, 2019 this is what i got: error on line 243398 at column 33: xmlParseEntityRef: no name
rkirchhof 1 Posted January 6, 2019 Posted January 6, 2019 This is what I see in the Emby log: System.Xml.XmlException: An error occurred while parsing EntityName. Line 244730, position 33. 100's of times.
wulfeman6869 1 Posted January 12, 2019 Author Posted January 12, 2019 i wanted to update this thread by saying the guide is working now. i guess it was and invalid xml.
