Help on reverse proxy on Synology
Go to solution Solved by mastrmind11,
Hi
I'm trying to use https for remote connections using Synology reverse proxy and letsencrypt certificate installed using DMS control panel.
Here what I did so far:
1. Setup DDNS using synology.me service
2. Create a letsencrypt certificate for this domain using DMS control panel
3. Create a reverse proxy setting on port 8921 to redirect to localhost:8096
4. Setup the https://*:8921 service to use the "mydomain".synology.me certificate
5. Setup port forwarding on my router to forward port 8921 to my nas port 8921
6. Setup emby advance settings, I set the external domain, https port and the secure connection mode to "Handled by reverse proxy".
Everthing is working greate except for 1 thing.
If I use https://"mydomain".synology.me:8921, I get a secure connection to emby server with the message : Secure connection: verified by Let's Encrypt.
However, if I use this url instead:
https://"mypublicip":8921, I get to my emby server on a unsecure connection with this message: "mypublicip":8921 uses an invalid security certificate.  The certificate is only valid for "mydomain".synology.me.
I can add an exception in the browser and get to my emby server on an unsecure connection, which defeat the purposeto have a secure connection at the first place.
Did I miss a setting somewhere, anything that could explain why I can get to my emby server on a unsecure connection through my public ip?
Thank you
mastrmind11
certs roll up to a domain name not an IP.  the cert has to match the domain you're connecting to.  ie, this is working as intended.
Thanks for quick reply
Is there a way to set the reverse proxy to not forward unsecure connetion?
If not I guess the only solution would be to set the certificate directly on emby server and set the secure connection mode to "require for all remote connection".  I tried the reverse proxy at the first place because it seems easier and quicker to renew the certificate every 3 months.
  • Solution
mastrmind11
I'm not familiar w/ Synology's method of proxying, but this is possible w/ true web servers like nginx or apache.  It might also be the letsencrypt cert.  In all honesty, just go get a domain name from namecheap or wherever and get a free cert from cloudflare.  Costs like $10 and is way simpler and lasts like 7 years or something before you have to renew.  there are tutorials all over the internet to set it up this way (as well as a bunch of posts on these forums).
  • Like 1
Thanks for the tips.
I got a domain name from freenom for 12 months and setup cloudflare.  I installed a set of certificates on emby server from cloudflare and it all working great.
I set the secure connection mode on emby server  to "required for all remote connections".  However, I still can log in and watch stuff using directly the publicip address and this connection is not secured.
What exactly does the parameter : secure connection mode?  I though setting this parameter would have blocked unsecure remote connection?
Edited by rouq
