chowbok 136 Posted December 19, 2018 Posted December 19, 2018 Since with a lot of movies a chapter start corresponds with a fade-in, many chapter images are just plain black squares. It seems like a simple way to fix this would be to grab the chapter image from the chapter timestamp + 5 seconds or so. Is this something that seems feasible? 3
Luke 42243 Posted December 19, 2018 Posted December 19, 2018 how many seconds of black does your video have between chapters?
chowbok 136 Posted December 19, 2018 Author Posted December 19, 2018 Well, it's not just one video this is happening with. Older movies used fade-ins a lot. I tested from a few different movies, and it seems to be 3-4 seconds.
hstamas 179 Posted June 7, 2019 Posted June 7, 2019 Just started playing with chapter images myself and I’m seeing the same thing with TV shows. Episodes that have actual, designated chapter marks that Emby is honoring usually occur when the show is coming back from where a commercial used to live so there is a fade in from black. Most of my chapter images are capturing this black screen. Example attached. I thing a 1-2 second offset would solve the problem.
Luke 42243 Posted June 7, 2019 Posted June 7, 2019 what is your thumbnail interval setting on the server?
hstamas 179 Posted June 7, 2019 Posted June 7, 2019 what is your thumbnail interval setting on the server? “Chapter markers”
Luke 42243 Posted June 8, 2019 Posted June 8, 2019 Strange. We actually already use a filter to try and avoid black images on chapters.
chowbok 136 Posted June 8, 2019 Author Posted June 8, 2019 Strange. We actually already use a filter to try and avoid black images on chapters. Really? I didn't realize that. It's not working for me, at least not always.
Luke 42243 Posted June 10, 2019 Posted June 10, 2019 Can you provide a sample video for testing? thanks.
chowbok 136 Posted October 14, 2023 Author Posted October 14, 2023 Too late to revive this thread? I have a good example file of what I was talking about, let me know if you'd still like to look at it and I'll put it up.
Luke 42243 Posted October 15, 2023 Posted October 15, 2023 Do you extract art chapters or the 10 second intervals?
Luke 42243 Posted October 16, 2023 Posted October 16, 2023 OK, there is currently no option for this, but this idea has come up before and is possible for future updates. Thanks.
Grimmer 15 Posted March 3, 2024 Posted March 3, 2024 (edited) Would love this feature as well. NCIS is a great example of this issue. Pulling images at the chapter markers always results in a black screen (except for the first chapter): A library level (and perhaps a TV show level override) of chapter mark + "X seconds" (and could accept + or - values). Edited March 3, 2024 by Grimmer 1
chowbok 136 Posted June 17, 2025 Author Posted June 17, 2025 Just wanted to do an annual ping on this. It seems like just adding a 10–15 second delay on the chapter images would fix this, and be easy to implement. 1
Grimmer 15 Posted June 17, 2025 Posted June 17, 2025 Could also add a quick calculation to sum the values from a few hundred pixels across the chapter screenshot. If the sum is below a certain threshold (that indicates a black/dark scene), advance 1 sec and try again and repeat as needed. A small (negligible?) additional load on the CPU, but could keep the chapter screenshot as close as possible to the start of the chapter. 1
chowbok 136 Posted June 17, 2025 Author Posted June 17, 2025 I just feel that the more complicated this is, the less likely it is to be implemented.
Luke 42243 Posted June 18, 2025 Posted June 18, 2025 We could always add a library option for this. 1
Grimmer 15 Posted June 18, 2025 Posted June 18, 2025 Would it be possible to have the server admin choose the delay value in the library settings? Is there already a default delay built in? 10-15 second is a very long time for video. Skipping over a chapter fade-in, could likely be handled by a 2 second delay.
Luke 42243 Posted June 18, 2025 Posted June 18, 2025 43 minutes ago, Grimmer said: Would it be possible to have the server admin choose the delay value in the library settings? Is there already a default delay built in? 10-15 second is a very long time for video. Skipping over a chapter fade-in, could likely be handled by a 2 second delay. Yes. There currently is no delay. The image extraction uses a filtering technique to avoid getting black frames, however this is a push/pull because the more aggressive we make that, the more people complain that the extraction takes too long. But making that configurable could be an alternative to a delay because then you actually get an image that corresponds with the chapter timestamp.
chowbok 136 Posted June 23, 2025 Author Posted June 23, 2025 (edited) On 6/18/2025 at 10:59 AM, Grimmer said: Would it be possible to have the server admin choose the delay value in the library settings? Is there already a default delay built in? 10-15 second is a very long time for video. Skipping over a chapter fade-in, could likely be handled by a 2 second delay. You're right, 10–15 seconds is unnecessarily long. 3–4 would probably be ideal, I think 2 isn't enough. I worry that Luke's proposed solution of auto-detecting black would take too long to implement. Edited June 23, 2025 by chowbok Submitted too soon
chowbok 136 Posted February 8 Author Posted February 8 Any luck with this? Still getting mostly black chapter images on my older movies.
