ucliker 2 Posted December 18, 2018 Posted December 18, 2018 I just started migrating over to Emby after Plex ruined the Roku app. After adding some of my libraries I noticed on the Emby home screen (dashboard) It created these really nice icons with images from the poster art. The problem is it didn't do that for all of the libraries (Anime is missing that). I attached a picture to show what I mean, is there a manual way to add that? I have a lot of libraries to add still I would love to know if I can add that to all the libraries.
saitoh183 137 Posted December 18, 2018 Posted December 18, 2018 You can put your own images. I just waited and it would eventually change after all the metadata was all done scanning
ucliker 2 Posted December 18, 2018 Author Posted December 18, 2018 You can put your own images. I just waited and it would eventually change after all the metadata was all done scanning Thanks, I don't want my own images. I just want uniformity with the icons.
Deathsquirrel 745 Posted December 18, 2018 Posted December 18, 2018 Has your initial library scan completed?
Luke 42216 Posted December 18, 2018 Posted December 18, 2018 Yea the important thing is that you'll need to wait for the initial scan to complete. Thanks !
Solution ucliker 2 Posted December 18, 2018 Author Solution Posted December 18, 2018 Thanks for the help. Yes the initial scan finished but I figured out that if a file doesn’t identify correctly then that images won’t show up. Once everything is fixed it shows up. 1
