Nisten 15 Posted December 18, 2018 Posted December 18, 2018 (edited) When i try to access the Transcoding section of the app, it just shows the loading wheel perpetually. It never actually loads so I can make changes. server log 12-17.txt 2nd server log 12-17.txt Edited December 18, 2018 by Nisten
Luke 42244 Posted December 18, 2018 Posted December 18, 2018 HI, the app is just a little bit ahead of your server right now. This will be resolved as soon as the 3.6 release goes stable. For now I would just do this with your web app. Please let us know if this helps. Thanks !
Nisten 15 Posted January 9, 2019 Author Posted January 9, 2019 Yep web app still works, i'll just wait for 3.6 then so its more convenient to change these settings on the fly
Solution Nisten 15 Posted January 23, 2019 Author Solution Posted January 23, 2019 Fixed with 4.0 release
