Aussiedroid 56 Posted January 20, 2019 Posted January 20, 2019 Thanks for the help Luke. Good to know. I'll see if it comes good/temporary thing, or if I might have to give this one a miss. Cheers, AD
vaise 340 Posted January 20, 2019 Author Posted January 20, 2019 (edited) Hey @@Aussiedroid, maybe you can start a ping test - from the same device used to stream the stuff - and see if you get dropoffs : ping sbslivefvstreaming.sbs.com.au -t Im getting a constent 8-9ms from here in Brisbane. Repeat for any connections with the same issue. May be an ISP/Internet thing. Are you on the NBN ? Anything else happening on your internet that may cause a dropout ? C:\Users\Vaise>ping sbslivefvstreaming.sbs.com.au -t Pinging a330.w10.akamai.net [104.117.181.64] with 32 bytes of data: Reply from 104.117.181.64: bytes=32 time=11ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 Reply from 104.117.181.64: bytes=32 time=8ms TTL=61 Reply from 104.117.181.64: bytes=32 time=8ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 Reply from 104.117.181.64: bytes=32 time=8ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 Reply from 104.117.181.64: bytes=32 time=8ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 Reply from 104.117.181.64: bytes=32 time=8ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 Reply from 104.117.181.64: bytes=32 time=9ms TTL=61 V. Edited January 20, 2019 by vaise 1
Aussiedroid 56 Posted January 20, 2019 Posted January 20, 2019 Thanks for the suggestion vaise! Seems good, attached a screenshot.
vaise 340 Posted January 20, 2019 Author Posted January 20, 2019 That seems all good - maybe have that ping running at the same time as trying to stream SBS, if the stream fails, look at the output to see if you lost contact for a period.
aaronsomek 13 Posted January 12, 2020 Posted January 12, 2020 Thanks so much for posting this guide. I got it set up in minutes and am now streaming in Melbourne with a working tv guide. Awesome.
Eds 0 Posted June 30, 2020 Posted June 30, 2020 Has anyone tried adding Australia TV via m3u on a SeedBox which supports Emby and got it working? The only channels working for me are the ABC channels from https://www.matthuisman.nz/2017/08/nz-au-iptv-epg-files.html?m=1 Thanks
vaise 340 Posted June 30, 2020 Author Posted June 30, 2020 Is the seedbox in Australia ? I believe many of the channels are geo locked. A VPN to Australia should get over that.
Eds 0 Posted June 30, 2020 Posted June 30, 2020 Thanks @vaise Seedbox is located in Germany. Great suggestion mate I'll get onto that. Do you know if a DNS provider would work just as well? E.g. DNS4ME? Cheers
vaise 340 Posted June 30, 2020 Author Posted June 30, 2020 I would exhaust all free/easy options first.
fusionoz 1 Posted March 29, 2021 Posted March 29, 2021 Hi guys been trying to set this up on my Emby server. I am based in Townsville and don't mind if I have to use Brisbane. When i try and get the file in the web browser it states the file is no longer available. I have put this in the File or URL section of the M3U tuner settings and no luck.
Carlo 4561 Posted March 30, 2021 Posted March 30, 2021 Don't know where you're getting your guide data from but you could try https://www.xmltv.net/
vaise 340 Posted March 31, 2021 Author Posted March 31, 2021 On 30/03/2021 at 06:56, fusionoz said: Hi guys been trying to set this up on my Emby server. I am based in Townsville and don't mind if I have to use Brisbane. When i try and get the file in the web browser it states the file is no longer available. I have put this in the File or URL section of the M3U tuner settings and no luck. Yep - looks like a few I just tried ar no longer working. Maybe the end points have changed and he has not updated his links ? You could try and contact him via the readit link on his website. I have a ton of HDHR tuners so I only originally posted this for others to use, I dont use it myself.
