Draxis 2 Posted December 17, 2018 Posted December 17, 2018 Am I supposed to be buying the sub before I can use apps?
Luke 42234 Posted December 17, 2018 Posted December 17, 2018 Hi, no, can you please describe the issue in more detail? Thanks !
Draxis 2 Posted December 17, 2018 Author Posted December 17, 2018 Well, I can input the code it gives me to invite the tv, which I then get invited to my server. But when I try to connect, it gives me that error.
Draxis 2 Posted December 18, 2018 Author Posted December 18, 2018 (edited) I can't connect to my android phone app either. So there's a setting on my server set up that's wrong. But I dont know what it is. I also have the port forward on my router for the pc the emby server is setup on. Edited December 18, 2018 by Draxis
Solution Draxis 2 Posted December 18, 2018 Author Solution Posted December 18, 2018 Nevermind, I had to create a port forward on windows firewall. 1
