WWWestern 94 Posted April 24, 2014 Posted April 24, 2014 Now are visible 20-24 in order. Others gone. Well done!
ebr 16342 Posted April 24, 2014 Author Posted April 24, 2014 0.1.0.3 is available now and will give you access to all media folders. Previously, there was no way to attach the "virtual" ones like Trailers and Podcasts.
Glyde62 50 Posted April 25, 2014 Posted April 25, 2014 Not working properly for me, If I go to all movies/tv it will play items But if I try playing a Movie/Tv Show via Next Up etc I get the Unable to launch Media Browser3 message
ebr 16342 Posted April 25, 2014 Author Posted April 25, 2014 Please find the error in the windows event log. Instructions are in the how to report a problem post.
DigiTM 60 Posted April 25, 2014 Posted April 25, 2014 (edited) If I deselect TV Genre View in the server, it still shows on MBC plugin. Edited April 25, 2014 by DigiTM
LiquidFX 144 Posted April 25, 2014 Posted April 25, 2014 I was lucky enough to be one of the Alpha testers and have loved using MBPlus for a while now
kkhan 16 Posted April 25, 2014 Posted April 25, 2014 Very cool! I want to use it to aggregate mixed content - for example a category called Bollywood containing both Bollywood movies and soundtracks. However, I found that I could not get a custom music channel to work. I created a custom music channel called Bollywood Soundtracks selecting all albums with genre Bollywood and then another custom movie channel called Bollywood Movies selecting all movies with genre Bollywood. The custom movie channel shows but not the custom music channel. Tried music, movie and custom music categories but the same result. The custom movie channel does not appear to be filtering correctly on genre. I can however add folders (I have bollywood movies and soundtracks in separate folders) and aggregate them in the category that way. Is what I am trying to do likely to be supported? Great work as always!
kkhan 16 Posted April 25, 2014 Posted April 25, 2014 Sorry, correction ...The custom music channel does not appear to be correctly on genre.
ebr 16342 Posted April 25, 2014 Author Posted April 25, 2014 If I deselect TV Genre View in the server, it still shows on MBC plugin. Good catch. Thanks.
ebr 16342 Posted April 25, 2014 Author Posted April 25, 2014 Very cool! I want to use it to aggregate mixed content - for example a category called Bollywood containing both Bollywood movies and soundtracks. However, I found that I could not get a custom music channel to work. I created a custom music channel called Bollywood Soundtracks selecting all albums with genre Bollywood and then another custom movie channel called Bollywood Movies selecting all movies with genre Bollywood. The custom movie channel shows but not the custom music channel. Tried music, movie and custom music categories but the same result. The custom movie channel does not appear to be filtering correctly on genre. I can however add folders (I have bollywood movies and soundtracks in separate folders) and aggregate them in the category that way. Is what I am trying to do likely to be supported? Great work as always! The music area, unfortunately, did not get much testing in the alpha phase. I'll look into it.
ebr 16342 Posted April 25, 2014 Author Posted April 25, 2014 Version 0.1.0.4 (of server plug-in) is available. Fixes the TV Genre view option problem and should improve custom music channels.
MrWebsmith 598 Posted April 25, 2014 Posted April 25, 2014 (edited) ... forgive me ebr, im only seeing 1.0.2 mbc plugin level is dev (plugin level on mbs is dev also) im on mbc.157... checked the catalog within mbc as well.. manually made it check for updates... what am i missing? also tried removing the plugin from within mbc and then backing out... then going back in and grabbing from the catalog again.. still gave me 1.0.2.. here's a cap of it not "seeing" the server version correctly... i assume that will be related.. https://www.dropbox.com/s/6o4xev0htl6mvmk/mbplusupdate.jpg Edited April 25, 2014 by MrWebsmith
ebr 16342 Posted April 25, 2014 Author Posted April 25, 2014 Web - your MBPlus.Classic plug-in is up to date. It is the server side that is not. Since you were on the alpha, you will need to manually install the server plug-in the first time because I manually changed the version numbers so your server version number appears larger than the one available now.
AdrianW 1058 Posted April 26, 2014 Posted April 26, 2014 Any chance of having multiple "Next Up" channels? And be able to set specifically which TV shows should be included in each. There's a number of shows I watch with my son, then a different set I watch with my son and daughter and then a another list that all four of us watch together.
ebr 16342 Posted April 26, 2014 Author Posted April 26, 2014 Well, it is actually possible to create custom channels for specific named items but that is a little complex and confusing so I didn't expose it in the configuration interface. With that, however, you could create a custom channel for those particular shows and select "Only Unwatched" and it would probably do what you want. I'm not positive I am going to expose it though... 1
ebr 16342 Posted April 28, 2014 Author Posted April 28, 2014 I think there are a number of people using this but I'm not seeing much in here as far as bug reports or feedback. If you are using it, please let me know how it is going. Thanks.
Starkadius 219 Posted April 29, 2014 Posted April 29, 2014 Okay I have been using it on and off in the past few days. The addition of being able to add media folders, awesome really wanted that. A feature I would like to see added at some point is "Genres" view for custom categories if it is not too much trouble. Overall I don't think you are getting much feedback because you already did a really fine job to begin with. Not much to fix/change, it just works. If I do happen to find some issues, I will be sure to mention them down the line.
AdrianW 1058 Posted April 29, 2014 Posted April 29, 2014 I uninstalled it yesterday. I like the idea and the presentation - but it's not really giving me anything usable in my environment. I hardly ever watch multiple episodes of the same show one after the other (and that's available from "play all from here" anyway). Never really have the time to watch more than one movie in a row. The killer feature for me is "Next Up" - but as I explained a couple of posts back, I'd really like multiple Next Up channels which only contain a mixture of specific shows each.
ebr 16342 Posted April 29, 2014 Author Posted April 29, 2014 A feature I would like to see added at some point is "Genres" view for custom categories if it is not too much trouble. A "Custom" category is intended to be just for media folders and custom channels - a way to customize the presentation of your normal content basically. But all of the category types are actually pretty customizable. If you want any special views, just create a category that is of the type of View you want to see and de-select the suggestions and latest if you don't want them to show. You can have multiple categories of the same type and, if you strip away the suggested and latest, it becomes a Custom one with Views of the type you select to show.
seanbuff 1357 Posted April 29, 2014 Posted April 29, 2014 @@ebr - am enjoying customizing this plugin to get the most out of it. I know you want some feedback or any bug reports. So just a quick one I've noticed, when changing the number of 'Suggestion' tiles to display for Movies, from 6 to 3 or 4... doesn't seem to have an effect in MB Plus Classic. Am I doing something wrong? Using MBPlus Classic 0.1.0.2 / Server 0.1.0.4 Sent from my Nexus 10 using Tapatalk
ebr 16342 Posted April 29, 2014 Author Posted April 29, 2014 Sounds like a bug. I'll look into it. Thanks.
Pelon 203 Posted April 29, 2014 Posted April 29, 2014 Is there a way to hide a show from the "Next up" feature? Just because I watch 1 episode of a show, it doesn't necesarily mean that I'm watching that show. This might be a server thing.
seanbuff 1357 Posted April 29, 2014 Posted April 29, 2014 Is there a way to hide a show from the "Next up" feature? Just because I watch 1 episode of a show, it doesn't necesarily mean that I'm watching that show. This might be a server thing. Would love to know if this is possible also.
ebr 16342 Posted April 29, 2014 Author Posted April 29, 2014 Is there a way to hide a show from the "Next up" feature? Just because I watch 1 episode of a show, it doesn't necesarily mean that I'm watching that show. This might be a server thing. Indirectly, yes. Select "Only Favorites in Next Up Channel" and then mark the series you would like to show up in there as favorites.
ebr 16342 Posted April 29, 2014 Author Posted April 29, 2014 @@ebr - am enjoying customizing this plugin to get the most out of it. I know you want some feedback or any bug reports. So just a quick one I've noticed, when changing the number of 'Suggestion' tiles to display for Movies, from 6 to 3 or 4... doesn't seem to have an effect in MB Plus Classic. Am I doing something wrong? Using MBPlus Classic 0.1.0.2 / Server 0.1.0.4 Sent from my Nexus 10 using Tapatalk This should be fixed in server version 0.1.0.5.
