Redshirt 1487 Posted December 22, 2014 Posted December 22, 2014 With MB Plus set to the Metro Case for seasons I'm noticing M*A*S*H only has the season number for the first season. Every other show has the season number for all seasons. The only thing that pops to mind is that M*A*S*H is the only show I have with more than 9 seasons.
ebr 16342 Posted December 22, 2014 Author Posted December 22, 2014 That would be a CA or metadata issue. Make sure those seasons actually have the Season Number in the metadata.
Redshirt 1487 Posted December 22, 2014 Posted December 22, 2014 Good call. It may be something wrong with the metadata. Season 1 <?xml version="1.0" encoding="utf-8" standalone="yes"?> <Item> <SeasonNumber>1</SeasonNumber> <Added>2014-08-24 2:58:10 PM</Added> <LockData>false</LockData> <LocalTitle>Season 1</LocalTitle> </Item> Season 2+ <?xml version="1.0" encoding="utf-8" standalone="yes"?> <Item> <Added>2014-08-24 2:57:57 PM</Added> <LockData>false</LockData> <LocalTitle>Season 2</LocalTitle> </Item> So who gets the bug report? You or Luke?
inzombyac 69 Posted December 22, 2014 Posted December 22, 2014 Okay, it sounds like there may be some sort of obscure bug there with the smart list. Registration should be very quick. However, I have not seen a recent transaction... I have the transaction ID if that helps.
ebr 16342 Posted December 22, 2014 Author Posted December 22, 2014 Good call. It may be something wrong with the metadata. Season 1 <?xml version="1.0" encoding="utf-8" standalone="yes"?> <Item> <SeasonNumber>1</SeasonNumber> <Added>2014-08-24 2:58:10 PM</Added> <LockData>false</LockData> <LocalTitle>Season 1</LocalTitle> </Item> Season 2+ <?xml version="1.0" encoding="utf-8" standalone="yes"?> <Item> <Added>2014-08-24 2:57:57 PM</Added> <LockData>false</LockData> <LocalTitle>Season 2</LocalTitle> </Item> So who gets the bug report? You or Luke? Not sure it is a bug. Could just be old metadata. Just fill in the season numbers in the editor.
ebr 16342 Posted December 22, 2014 Author Posted December 22, 2014 I have the transaction ID if that helps. PM me a screen shot of the email you received from PayPal.
Redshirt 1487 Posted December 22, 2014 Posted December 22, 2014 (edited) I've deleted both my season.nfo and season.xml file for each season. I've also added the season number in the metadata editor. Done a library scan and the issue remains. We have so much metadata garbage being generated now it's hard to tell what's relevant and what's not. Edited December 22, 2014 by Redshirt
ebr 16342 Posted December 22, 2014 Author Posted December 22, 2014 You would need to refresh the affected seasons (perhaps replacing images as well) to cause the images to be re-processed.
skynet600 33 Posted December 24, 2014 Posted December 24, 2014 Hi Eric, my no items in mbplus genre issue is back. I can assure you I am not doing anything to break this. From the no mbplus home screen I can go to movies by genre and all is well. Not so when I go into mbplus.
ebr 16342 Posted January 7, 2015 Author Posted January 7, 2015 A new feature coming soon to MB Plus. In trying out some new series or watching some bad movies I've found myself wishing that I could tell MB Plus to forget that I watched something and take it out of my suggestions. So... A new context menu option on playlist tiles where you can tell MB Plus to forget one of these items and then it won't keep it in your suggestions - unless you play it again. 1
inzombyac 69 Posted January 25, 2015 Posted January 25, 2015 Is there any way to get search to work from the MB Plus home screen? Right now, the only way to search is to drill into a folder/item on the home screen.
ebr 16342 Posted January 25, 2015 Author Posted January 25, 2015 Yeah, that's a good idea when I get some free time.
Airfleet 0 Posted February 4, 2015 Posted February 4, 2015 I recently moved my server to a dedicated pc. After the move the custom player interface in MB Plus will only allow play and pause functions. Skipping fwd or back doesn't work, but works fine inside of Classic, when I don't go into MB Plus. It worked great for several months before the move, when both the server and client were on the same machine. I've tried several different configurations, still no luck. It seems to be server based, since I have the same problem on two clients running Classic. After lots of research and configuration changes, I'm stumped. I'm hoping someone else has run into this problem and found a fix, I'd sure miss MB Plus. Same result whether I use a mouse or remote (entering skip fwd numbers), or uninstall and reinstall.
ebr 16342 Posted February 4, 2015 Author Posted February 4, 2015 This doesn't sound like an MB Plus issue. What are you calling the "MB Plus custom player interface"? The player interface is just a part of MBC and is completely independent of MB Plus. It sounds to me like you haven't setup your library with UNC paths or proper sharing such that the MBC machine can access the files and so they are streaming instead - which would limit your ability to seek.
Airfleet 0 Posted February 4, 2015 Posted February 4, 2015 Thanks for your quick response, ebr. I suspect you're probably right about something network related, since I never had this problem when both the server and client were on the same machine. I should have clarified myself, actually it's the same custom interface that MBC uses. The only difference is that it works in MBC and doesn't in MB Plus (except play and pause). Unfortunately, I don't have the expertise on UNC paths, servers or networks. My MBC client works perfectly (all controls), it's only when I enter MB Plus that I have problems with the interface.
ebr 16342 Posted February 4, 2015 Author Posted February 4, 2015 Are you playing the exact same things because I don't see how MB Plus could possibly affect playback or access to the items. You will need to use UNC paths and have proper network access setup for MBC to be able to direct play any of your content.
Airfleet 0 Posted February 4, 2015 Posted February 4, 2015 I'm able to play any of my video library, in MBC, with full control and great quality. I can then move into Plus and play the same file, but I lose the control (except play/pause), but I still have good audio/video quality. The only change seems to be the player interface control working and the then not working, depending on being in Plus or not. It's a mystery for sure!
ebr 16342 Posted February 4, 2015 Author Posted February 4, 2015 An MBC log when you do both of those things would certainly help uncover it .
AgileHumor 123 Posted February 5, 2015 Posted February 5, 2015 (edited) delete me, pii cleanup Edited April 17, 2015 by AgileHumor
ebr 16342 Posted February 5, 2015 Author Posted February 5, 2015 It pretty much already is that. However, whatever is going to utilize the features of MB Plus has to know how to talk to it. MB Plus has its own API. I stated when I created it that I would help any dev who wanted to build something that talked to that API and I do have plans to eventually implement an MB Plus interface in other clients. I'd like to get it into MBT but need for that platform to stabilize first. I will probably also get an MB Plus view into my new Android TV app once I have most of the other basic features done for it because I plan to replace my kids' Roku with an Android TV device and they can utilize the MB Plus interface as well. 1
AgileHumor 123 Posted March 30, 2015 Posted March 30, 2015 (edited) delete me, pii cleanup Edited April 17, 2015 by AgileHumor
BillW 30 Posted March 31, 2015 Posted March 31, 2015 Server version 3.0.5569 installed automatically tonight when I turned on my HTPC. When the system finished updating I got an error message pop up box shown, When I close the error message the server stops. I uninstalled MB Plus, the server worked fine. Rei-installing MB Plus causes the error message to appear again. I was running the release version, Any help would be appreciated.
ebr 16342 Posted April 1, 2015 Author Posted April 1, 2015 Sorry. Update MB Plus and you should be fine.
inzombyac 69 Posted April 2, 2015 Posted April 2, 2015 This might be a suggestion, and if so I'll post it there. Is there a way to give Next Up more weight or make its own tile group? Ideally, when I start Emby classic I want Next Up to be the default icon so I can click OK and start playing. The only way I have found to do so is to turn off "Show Views" and limit the Suggestions to 1 tile. Thanks again.
