AdrianW 1058 Posted April 22, 2014 Posted April 22, 2014 I still use metabrowser for my metadata and images fetching. In MBS I have: Download artwork and metadata from the internet: OFF Save artwork and metadata into media folders: ON Image saving convention: Standard MB2/MB3 If I change a backdrop or a show / season poster image in metabrowser - the folder.jpg or backdrop.jpg (backdrop1.jpg, etc) is replaced (and the date modified is updated). But, the original image(s) still show in MBS. That's reasonable as they're probably cached somewhere - but even after running a "Scan Media Library" the old images still show up in MBS (and in MBC). If I change the images via the MBS interface then the new ones show up in both MBS/MBC and metabrowser - but I'd prefer to continue to use metabrowser if possible.
ebr 16305 Posted April 22, 2014 Posted April 22, 2014 Is the Creation Date in Windows modified when you replace the image with MetaB?
AdrianW 1058 Posted April 22, 2014 Author Posted April 22, 2014 Is the Creation Date in Windows modified when you replace the image with MetaB? Nope. But, I just manually changed the creation date on folder.jpg - and ran a scan, and MBS still shows the original image.
