Guest Posted December 14, 2018 Posted December 14, 2018 (edited) I'm looking for a way to create a new user, e.g. "kid", and only "white-list" a few TV shows and a movie or two. After searching for similar questions, the most relevant existing answer is this: You would need to arrange your items into different folders at the same level and then setup the library pointing to those folders. e.g.: TV\Our shows TV\Her shows TV\His shows Then point the library to all three of those and give access accordingly. Or, you could use tags with the Parental Controls feature to just block individual shows. However, in the first case you need to physically re-order things on your storage, and keep consciously doing that. It gets even harder when you have multiple users (e.g. "his", "hers", "kid") and some items are available for a subset of them. In the second case you need to tag everything and keep tagging everything new, just so you can allow two TV Shows by not tagging them. This also gets complex with multiple users, because you have to tag everything with a blacklist-tag for every user so you can untag them for certain users without affecting the other user. I don't know what is the history of this functionality and if the way it's set up is due to technical limitations, so please forgive me if this question sounds ignorant: Wouldn't it be orders of magnitude easier if we could whitelist a specific tag (e.g. in parental controls) for a user, rather than blacklisting everything else? Edited December 14, 2018 by Redsandro
mastrmind11 722 Posted December 14, 2018 Posted December 14, 2018 Wouldn't it be orders of magnitude easier if we could whitelist a specific tag (e.g. in parental controls) for a user, rather than blacklisting everything else? yeah this has been a feature request for some time now.
Guest Posted December 14, 2018 Posted December 14, 2018 yeah this has been a feature request for some time now. I hadn't found it before I posted. Do you happen to know if there's a thread or issue that I can track?
mastrmind11 722 Posted December 14, 2018 Posted December 14, 2018 I hadn't found it before I posted. Do you happen to know if there's a thread or issue that I can track? There's definitely a FR thread. I'd have to search for it. Doubt there's an issue to track, though.
