solabc16 379 Posted December 15, 2018 Author Posted December 15, 2018 (edited) Hi @@softworkz Ok, understood, and just to clarify 'vainfo' and 'ffdetect' (with the latest beta) are both available and installed by default with both the 'netframework' and 'netcore' packages for Synology/XPEnology. For reference, users can run them as follows, once they've SSH'd into their systems as 'admin'... netframework cd /var/packages/EmbyServer/target/ffmpeg/bin/ sudo ./vainfo sudo ./ffdetect [command line] netcore cd /var/packages/EmbyServerNET/target/ffmpeg/bin/ sudo ./vainfo sudo ./ffdetect [command line] If you do need an updated FFdetect pushed out to assist with testing, just let me know. To confirm, 'libva2' is definitely available - e.g. see output here https://emby.media/community/index.php?/topic/66484-36074-beta-onward-vaapi-broken-on-braswell-based-systems/?p=661802 Best - James Edited December 15, 2018 by solabc16
softworkz 5133 Posted December 15, 2018 Posted December 15, 2018 Thank you very much for the update. I'll follow up privately about new builds.
postboy99 4 Posted December 17, 2018 Posted December 17, 2018 (edited) Hi @@softworkz since Version 3.6.0.78 even software transcoding doesn't work. When I start transcoding nothing happens and I see tons of ffmpeg_logs. They all end with this error: x264 [error]: high profile doesn't support lossless [libx264 @ 0xd40940] Error setting profile high. [libx264 @ 0xd40940] Possible profiles: baseline main high high10 high422 high444 Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Conversion failed! ffmpeg_log.txt hw_detection_log.txt Edited December 17, 2018 by postboy99
Luke 42241 Posted December 17, 2018 Posted December 17, 2018 Did you customize the crf in transcoding settings? try setting that back to default.
postboy99 4 Posted December 17, 2018 Posted December 17, 2018 Thx Luke. The CRF setting was empty and I didn't touch it. Set that to default (23) and it worked. I don't know why it was empty though.
Luke 42241 Posted December 17, 2018 Posted December 17, 2018 Thanks for the feedback. We will review this @@softworkz
Solution solabc16 379 Posted December 22, 2018 Author Solution Posted December 22, 2018 Hello All I've just published 3.6.0.80-1-beta, so if you're on the beta channel and have a 'braswell' based system, this update includes a possible fix for this. Once installed, please let us know how you get on and would appreciate if you can run the Send Logs utility. Details here : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James
postboy99 4 Posted December 23, 2018 Posted December 23, 2018 @@solabc16 It's working with auto and I can see vaapi in advanced mode. Thank you!
solabc16 379 Posted December 23, 2018 Author Posted December 23, 2018 Thanks for the update @@postboy99, just in time for the holidays...! If you get a chance, could you run the Send Logs utility. Best - James
postboy99 4 Posted December 23, 2018 Posted December 23, 2018 Sure @@solabc16 sendlogs_NAS_synology_braswell_716+_20181223T181537UTC.tgz sent.
solabc16 379 Posted December 23, 2018 Author Posted December 23, 2018 Thanks @@postboy99, that's looking good. Best - James
