FrostByte 5453 Posted December 13, 2018 Posted December 13, 2018 Sorry for asking a newbie question but how do I join the Samsung beta program? Jim Not Samsung beta. Server beta. Luke is adding code to the latest server beta to get around this issue until Samsung releases the updated app he gives them. For Windows click the link below, other servers like Synology will have different ways to get the beta. http://embydata.com/downloads/server/beta12/setup.exe 1
jbirmingham40 9 Posted December 14, 2018 Posted December 14, 2018 Unfortunately I need the Linux install. Does not seem like this fix has been posted yet for Linux. Will continue to monitor. Thanks. Jim
Luke 42241 Posted December 14, 2018 Posted December 14, 2018 We'll have it up in the morning. Thanks and apologies for the disruption. 1
shadetree 6 Posted December 14, 2018 Posted December 14, 2018 We'll have it up in the morning. Thanks and apologies for the disruption. OK, Thanks again.
Andori 9 Posted December 14, 2018 Posted December 14, 2018 Same problem on a KS7500 with 1.0.48 and either 3.5.0.53 or 3.6.0.76 Beta on a Qnap TS-453A
Luke 42241 Posted December 14, 2018 Posted December 14, 2018 I've added a workaround to this in beta server 3.6.0.77, which is currently rolling out. Thanks guys. 1
jbirmingham40 9 Posted December 14, 2018 Posted December 14, 2018 Thanks for the quick fix. The workaround does in fact fix the infinite circle issue when you click play next. Unfortunately it does not fix the other issue with no programs showing up when you click on a season. The screen still only shows the row of buttons (e.g. Play, ..., and checkmark). There is nothing displayed below that.
Luke 42241 Posted December 14, 2018 Posted December 14, 2018 Thanks for the quick fix. The workaround does in fact fix the infinite circle issue when you click play next. Unfortunately it does not fix the other issue with no programs showing up when you click on a season. The screen still only shows the row of buttons (e.g. Play, ..., and checkmark). There is nothing displayed below that. Right yes, this issue is only impacting the beta server, so stable users aren't seeing it. The app has an update to resolve this with it's next version, but I will see if I can add another workaround to the server for it. Thanks. 1
KingOfTheHaggi 3 Posted December 14, 2018 Posted December 14, 2018 Right yes, this issue is only impacting the beta server, so stable users aren't seeing it. The app has an update to resolve this with it's next version, but I will see if I can add another workaround to the server for it. Thanks. i had the issue before beta and with beta but the beta server update helps as i can now populate the seasons episodes via the next episode button (screwed if it aint showing a next episode mind you) then i can go to end of the season its showing play that episode then click the jump button (play button with a line) and the next season episode 1 will play e.g season 1 episode 13 will get me to season 2 episode 1 if 13 was the last episode of season 1 when i press the jump button i also notice if i go into the blank seasons folders and mark it as read it does the same thing so there is that options (experimenting on a series i dont care about) hopefully this makes sence my brain is a bit "wonky"
emby-noob 8 Posted December 15, 2018 Author Posted December 15, 2018 Right yes, this issue is only impacting the beta server, so stable users aren't seeing it. The app has an update to resolve this with it's next version, but I will see if I can add another workaround to the server for it. Thanks. Was this for the same Samsung app that I had originally posted regarding? I'm not on the beta server, I was going to try today when the fix was released, but have only been on the stable one, in case that helps at all.
jbirmingham40 9 Posted December 15, 2018 Posted December 15, 2018 (edited) The no episodes showing problem was happening with the latest GA release and is still happening with the latest beta. Something about the latest Samsung firmware upgrade caused this to start happening. :-( Edited December 15, 2018 by jbirmingham40
shadetree 6 Posted December 15, 2018 Posted December 15, 2018 Thanks for the beta .77, all working as expected now.
Luke 42241 Posted December 15, 2018 Posted December 15, 2018 The no episodes showing problem was happening with the latest GA release and is still happening with the latest beta. Something about the latest Samsung firmware upgrade caused this to start happening. :-( Can you go to your series library settings and disable the advanced setting to automatically group series from mulitple folders. Then run a library scan. Then restart the Samsung app and see if that makes a difference. Thanks.
emby-noob 8 Posted December 15, 2018 Author Posted December 15, 2018 Can you go to your series library settings and disable the advanced setting to automatically group series from mulitple folders. Then run a library scan. Then restart the Samsung app and see if that makes a difference. Thanks. Not the person you replied to, but after upgrading to beta I can play videos again while the season folders are showing up empty for me too. Just tried to ungroup and rescan, but no change.
jbirmingham40 9 Posted December 15, 2018 Posted December 15, 2018 Can you go to your series library settings and disable the advanced setting to automatically group series from mulitple folders. Then run a library scan. Then restart the Samsung app and see if that makes a difference. Thanks. I do not have that option enabled.
tman 47 Posted December 15, 2018 Posted December 15, 2018 (edited) Experiencing this on my UE65KS8000 too with Tizen app v1.0.48 and Server 3.5.3.0 running on Windows. Any idea when the fix will be rolled into a full server release (I don't tend to run the beta releases)? Thanks. Edited December 15, 2018 by tman
Luke 42241 Posted December 15, 2018 Posted December 15, 2018 We'll have a new stable release very soon. Thanks ! 1
KingOfTheHaggi 3 Posted December 16, 2018 Posted December 16, 2018 since i am hijacking multiple threads with similar issue i will now link them all with post i just created encase it helps someone who doesnt want to run the beta or is on the beta (please dont hurt me to much ) https://emby.media/community/index.php?/topic/63895-tizen-app-is-not-showing-season-episodes/&do=findComment&comment=663188 1
Luke 42241 Posted January 4, 2019 Posted January 4, 2019 1.0.53 has launched for 2016 devices to resolve the issue of episodes not appearing on the season screen. I apologize for this issue. Thank you guys for your patience. 1
Luke 42241 Posted May 28, 2019 Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks !
Luke 42241 Posted June 30, 2019 Posted June 30, 2019 For those interested, Install from USB: https://emby.media/community/index.php?/topic/74969-samsung-tizen-install-from-usb/
