JBX 3 Posted December 11, 2018 Posted December 11, 2018 I deleted a couple of box sets created by the plugin and added all those movies to one manually created box set. I don't care about The Rescuers Collection box sets. I would like to group all (>40) Disney movies in one Disney Collection box set. But when the library is rescanned all those box sets appear again. Is there an option to permanently delete them?
Luke 42254 Posted December 11, 2018 Posted December 11, 2018 Hi, I don't believe so. Now that the plugin has processed your library you may want to just remove it.
JBX 3 Posted December 11, 2018 Author Posted December 11, 2018 And update future Box Sets manually? That's an idea... I have to think about it. Thanks.
Luke 42254 Posted December 11, 2018 Posted December 11, 2018 Yes or just install it periodically, run it, uninstall.
JBX 3 Posted December 11, 2018 Author Posted December 11, 2018 Can I remove the box set id from the metadata and run it again? Or will that be added again after a library scan? I’m just trying to think of a way to prevent it from re-adding box sets which I removed manually.
Luke 42254 Posted December 11, 2018 Posted December 11, 2018 Can I remove the box set id from the metadata and run it again? In theory yes that should work.
JBX 3 Posted December 11, 2018 Author Posted December 11, 2018 I confirm that changing or removing TheMovieDB Collection ID in the metadata fixes my issue. Thanks. 1
