Barlog9511 17 Posted December 11, 2018 Posted December 11, 2018 Hi I have a problem with True HD audio, Problem is in an android application as well I have version 3.6.0.76 of emby a later stable version of FreeNAS and Samsung TV application in version 1.0.44 everything works just fine when I play DTS audio, but in TrueHD audio, it TV output looks like this server_log.txt remux_log.txt server_log_longer.txt
SamES 1084 Posted December 11, 2018 Posted December 11, 2018 Playback of the TrueHD track will not be possible, so it should be repackaging the audio. The transcode log looks like it's doing the right thing, but the output definitely isn't right. I will try and see if I can reproduce this tonight. ffmpeg is supposed to be just copying the video stream (which it appears to be from the log, but not the screen)
softworkz 5133 Posted December 11, 2018 Posted December 11, 2018 Simple solution: Play DTS audio. It will be converted to AC3 anyway, just like TrueHD, so there's no point in choosing TrueHD. From a technical point of view: There's just two possibilities: Either the transcoder (ffmpeg) has a bug and creates an invalid file format Or there's a bug in a decoder or demuxer in the TV We'd need to analyze the output to see what's actually happening. Another thing I'm wondering about: /usr/local/lib/emby-server/bin/ffmpeg -f matroska -i file:"/Movies/4K/Avengers - Infinity War/ Avengers.Infinity.War.2018.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos.DD5.1.CZ.H.265-FCtU.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -c:v:0 copy -copyts -vsync -1 -codec:a:0 ac3 -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 6 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/db/emby-server/transcoding-temp/459121e7a43027e4397fbdd24c8127a6.m3u8" -y "/var/db/emby-server/transcoding-temp/459121e7a43027e4397fbdd24c8127a6%d.ts" We're encoding audio to 6-channel AC3 with a target bitrate of 192kbps only. @@Luke - can this be rightt?
softworkz 5133 Posted December 11, 2018 Posted December 11, 2018 I don't have much knowledge in that area, I don't even known if that value is meant per channel, per 2 channel pairs or total. So I was rather wondering if those 192k are correct (conforming to the AC3 spec).
Luke 42241 Posted December 11, 2018 Posted December 11, 2018 It's the total for the audio stream. 192k should be fine though so I can't imagine that's the problem.
softworkz 5133 Posted December 11, 2018 Posted December 11, 2018 192 seemed a bit low for 6 channels, but if that's a normal value then it's fine. I was just guessing for potential anomalies..
Luke 42241 Posted December 11, 2018 Posted December 11, 2018 It is low, and I will increase it, but I doubt it's responsible for this. 1
SamES 1084 Posted December 12, 2018 Posted December 12, 2018 So I tried playing a 4K HEVC stream with a TrueHD audio track, I get the same issue with video breakup and colour artefacts. I can confirm that the video stream was copied by ffmpeg while the audio is converted to AC3. If I select another audio track so that it DirectPlays, then the picture is perfect. This confirms to me that there is no problem with playback of the video stream. If I go back to the TrueHD track so that .ts segment files are created, if I try and playback any of these segments using vlc (Windows or Mac), Microsoft Video player, etc then all the segments display the same break-up and artefacts. There is something not right when these streams are created, or this is just not going to work how we expect for these video stream types. I did read somewhere that “The container format for HEVC video MUST be fMP4,” ie: no mpeg-ts streams for HLS. Not sure whether this is an issue. If I compare the MediaInfo for a stream segment to the original the only difference I can see is that in the original: Codec ID : V_MPEGH/ISO/HEVC and in the segment Codec ID : 36 Whether this would make a difference on playback, I just don't know. Could this also be a HDR issue? I expect you should be able to replicate this easily with any 4K HEVC file. Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 44 min Bit rate : 12.4 Mb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.084 Stream size : 9.03 GiB (72%) Writing library : x265 2.5+27-0e168bdeb48b:[Windows][GCC 6.2.1][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=150285 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) / max-cll=500,200 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 500 cd/m2 Maximum Frame-Average Light Level : 200 cd/m2
Luke 42241 Posted December 12, 2018 Posted December 12, 2018 Support for HEVC in HLS varies from one device to another. But maybe you've found the answer - HDR Hevc in HLS. Do you have non-hdr hevc to compare with?
SamES 1084 Posted December 12, 2018 Posted December 12, 2018 I'll play around a bit more tonight and see if I can narrow it down to HDR.
Barlog9511 17 Posted January 4, 2019 Author Posted January 4, 2019 @SamES do you have any update of this issue?
SamES 1084 Posted January 6, 2019 Posted January 6, 2019 Sorry, I'm just back from being away. I'll try and confirm this week.,
SamES 1084 Posted January 11, 2019 Posted January 11, 2019 (edited) Support for HEVC in HLS varies from one device to another. But maybe you've found the answer - HDR Hevc in HLS. Do you have non-hdr hevc to compare with? It's not a HDR issue. I've got another HEVC/4K/HDR file with TrueHD and it DirectStreams fine. It's even a much higher bit rate. I really don't know why one plays fine and not the other. There is some encoding differences between the files I have so I suspect that the way the video stream has been encoded is impacting it's ability to be split and streamed via HLS. Are you able to send me the MediaInfo output for you file to confirm? Thanks Edited January 11, 2019 by SamES
Barlog9511 17 Posted January 16, 2019 Author Posted January 16, 2019 Hi @@SamES I update Emby to version 4.0.2 and artifacts disappear, but I have problems with playing as well this is my media info output General Unique ID : 78162701324270964954682774450656844174 (0x3ACD96B52391CDE15DE8E7B19C45198E) Complete name : Z:\Filmy\4K\The Darkest Minds\The Darkest Minds(2018)(CZEN)[HEVC][2160pHD].mkv Format : Matroska Format version : Version 4 File size : 49.5 GiB Duration : 1 h 43 min Overall bit rate mode : Variable Overall bit rate : 68.3 Mb/s Encoded date : UTC 2018-10-29 22:26:00 Writing application : mkvmerge v28.0.0 ('Voice In My Head') 64-bit Writing library : libebml v1.3.6 + libmatroska v1.4.9 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 43 min Bit rate : 62.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.315 Stream size : 45.5 GiB (92%) Writing library : ATEME Titan File 3.8.16 (4.8.16.0) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 1 h 43 min Bit rate mode : Variable Bit rate : 4 384 kb/s Maximum bit rate : 8 790 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Delay relative to video : -1 ms Stream size : 3.18 GiB (6%) Language : English Default : Yes Forced : No Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 43 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -1 ms Stream size : 475 MiB (1%) Language : English Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 43 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 333 MiB (1%) Language : Czech Service kind : Complete Main Default : No Forced : No Text ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 42 min Bit rate : 44.7 kb/s Count of elements : 2576 Stream size : 32.8 MiB (0%) Language : Czech Default : Yes Forced : No
