highonascii 43 Posted December 11, 2018 Posted December 11, 2018 Basically in my settings I have subtitles off, when I auto play a tv series season in kodi the first episode will have subs off but then when a new episode plays it will force them on. I don't have a log handy because I noticed this last night as I was going to bed and had to work all day, but I wanted to report now anyways and see if this is a know issue. If needed I will replicate and provide log tomorrow when I have the time. Cheers!
djhifi 56 Posted December 11, 2018 Posted December 11, 2018 (edited) What KODI version you're on? What Emby for KODI version you're on? Skin? May or may not be related, but try this private version: https://emby.media/community/index.php?/topic/66093-3135a-seems-to-be-interfering-with-auto-displaying-subtitles-on-kodi/?p=658087 (plugin.video.emby-3.1.35b.zip) Play something, turn subtitles off (or if they are off, doesn't matter) but pull the OSD and go to "Video" scroll down and "Set as default for all media". Test it. Edited December 11, 2018 by djhifi
highonascii 43 Posted December 12, 2018 Author Posted December 12, 2018 (edited) What KODI version you're on? What Emby for KODI version you're on? Skin? May or may not be related, but try this private version: https://emby.media/community/index.php?/topic/66093-3135a-seems-to-be-interfering-with-auto-displaying-subtitles-on-kodi/?p=658087 (plugin.video.emby-3.1.35b.zip) Play something, turn subtitles off (or if they are off, doesn't matter) but pull the OSD and go to "Video" scroll down and "Set as default for all media". Test it. Thanks I'll give that a try now. And I am always on newest version of everything, kodi 18 nightly (I use default skin), emby server beta, etc..Cheers! Edited December 12, 2018 by highonascii
highonascii 43 Posted December 12, 2018 Author Posted December 12, 2018 Subs not popping up anymore! :D
Angelblue05 4132 Posted December 13, 2018 Posted December 13, 2018 Yep I will be posting a new build very soon. Thank you for your patience. 1
highonascii 43 Posted December 13, 2018 Author Posted December 13, 2018 Yep I will be posting a new build very soon. Thank you for your patience. Take your time
