Luke 42198 Posted February 24, 2019 Posted February 24, 2019 Just tried that in a bunch of apps including the browser and vlc is the only one that could handle it so there must be something non standard about it.
CChris 59 Posted February 24, 2019 Posted February 24, 2019 (edited) OK. VLC is showing as Streaming Info the following URL, which is also working well in Firefox and Chrome: http://dg-swr-http-dus-dtag-cdn.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3 I've updated the strm file and recreated my "radio" Library...Now, Emby is only showing the rotating "loading" circle... without any error or playback :-( Edited February 24, 2019 by CChris
Luke 42198 Posted February 24, 2019 Posted February 24, 2019 How to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
CChris 59 Posted February 24, 2019 Posted February 24, 2019 (edited) hi, Short error description:After using the link http://dg-swr-http-dus-dtag-cdn.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3 Using Firefox and Chrome, I'm getting the Error Message that no compatible stream could be found, with the following information in the error logs: 2019-02-24 19:43:51.077 Info App: User policy for Christoph.Caina. EnableAudioPlaybackTranscoding: True 2019-02-24 19:43:51.078 Info App: [LinuxMount] Checking we can attempt to mount [/volume1/music/emby/04_Radio/SWR 3/swr3.strm], Extension = [.strm], Operating System = [Linux], Executables Available = [True]. 2019-02-24 19:43:51.078 Info HttpClient: HttpClientManager GET: http://swr-swr3-live.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3 2019-02-24 19:43:51.194 Info HttpServer: HTTP Response 200 to 109.192.243.27. Time: 121ms. http://media.caina.de:8096/emby/Audio/23175/universal?UserId=cf29c9bee8f04205b17d4b8333565b21&DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NTAwMTA5MzQ0Mjk1&MaxStreamingBitrate=700000000&Container=opus,mp3|mp3,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav,ogg&TranscodingContainer=ts&TranscodingProtocol=hls&AudioCodec=aac&PlaySessionId=1551033827108&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false 2019-02-24 19:43:51.221 Info HttpServer: HTTP GET http://media.caina.de:8096/emby/Audio/23175/universal?UserId=cf29c9bee8f04205b17d4b8333565b21&DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NTAwMTA5MzQ0Mjk1&MaxStreamingBitrate=700000000&Container=opus,mp3|mp3,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav,ogg&TranscodingContainer=ts&TranscodingProtocol=hls&AudioCodec=aac&PlaySessionId=1551033827108&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.223 Info App: User policy for Christoph.Caina. EnableAudioPlaybackTranscoding: True 2019-02-24 19:43:51.225 Info App: [LinuxMount] Checking we can attempt to mount [/volume1/music/emby/04_Radio/SWR 3/swr3.strm], Extension = [.strm], Operating System = [Linux], Executables Available = [True]. 2019-02-24 19:43:51.229 Error HttpServer: Error processing request *** Error Report *** Version: 4.0.2.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.18.0.240 (tarball Fri Jan 18 15:40:28 UTC 2019) Processor count: 2 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.0.2.0 System.ArgumentException: System.ArgumentException: The 'Range' header must be modified using the appropriate property or method. Parameter name: name at System.Net.WebHeaderCollection.ThrowOnRestrictedHeader (System.String headerName) [0x0002f] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebHeaderCollection.Set (System.String name, System.String value) [0x0001c] in <06b225350c3541b2a422a59539189a6b>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.AddRequestHeaders (System.Net.HttpWebRequest request, MediaBrowser.Common.Net.HttpRequestOptions options) [0x0007a] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.GetRequest (MediaBrowser.Common.Net.HttpRequestOptions options, System.String method) [0x00062] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x000b0] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x0009e] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.GetStaticRemoteStreamResult (Emby.Server.MediaEncoding.Api.StreamState state, System.Collections.Generic.Dictionary`2[TKey,TValue] responseHeaders, System.Boolean isHeadRequest, System.Threading.CancellationTokenSource cancellationTokenSource) [0x00136] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest (Emby.Server.MediaEncoding.Api.StreamRequest request, System.Boolean isHeadRequest) [0x00284] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.UniversalAudioService.GetUniversalStream (Emby.Server.MediaEncoding.Api.GetUniversalAudioStream request, System.Boolean isHeadRequest) [0x0073e] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult (System.Threading.Tasks.Task task) [0x00081] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, MediaBrowser.Model.Services.IRequest httpReq, MediaBrowser.Model.Services.IResponse httpRes, MediaBrowser.Model.Logging.ILogger logger, System.String operationName, System.Threading.CancellationToken cancellationToken) [0x0023e] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler (MediaBrowser.Model.Services.IRequest httpReq, System.String urlString, System.String host, System.String localPath, System.Threading.CancellationToken cancellationToken) [0x00af1] in <5837600bbe23491d837720283845e3f2>:0 Source: mscorlib TargetSite: Void Throw() at System.Net.WebHeaderCollection.ThrowOnRestrictedHeader (System.String headerName) [0x0002f] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebHeaderCollection.Set (System.String name, System.String value) [0x0001c] in <06b225350c3541b2a422a59539189a6b>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.AddRequestHeaders (System.Net.HttpWebRequest request, MediaBrowser.Common.Net.HttpRequestOptions options) [0x0007a] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.GetRequest (MediaBrowser.Common.Net.HttpRequestOptions options, System.String method) [0x00062] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x000b0] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x0009e] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.GetStaticRemoteStreamResult (Emby.Server.MediaEncoding.Api.StreamState state, System.Collections.Generic.Dictionary`2[TKey,TValue] responseHeaders, System.Boolean isHeadRequest, System.Threading.CancellationTokenSource cancellationTokenSource) [0x00136] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest (Emby.Server.MediaEncoding.Api.StreamRequest request, System.Boolean isHeadRequest) [0x00284] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.MediaEncoding.Api.UniversalAudioService.GetUniversalStream (Emby.Server.MediaEncoding.Api.GetUniversalAudioStream request, System.Boolean isHeadRequest) [0x0073e] in <8d3c2eae278a44b89027f6e03c623f02>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult (System.Threading.Tasks.Task task) [0x00081] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, MediaBrowser.Model.Services.IRequest httpReq, MediaBrowser.Model.Services.IResponse httpRes, MediaBrowser.Model.Logging.ILogger logger, System.String operationName, System.Threading.CancellationToken cancellationToken) [0x0023e] in <5837600bbe23491d837720283845e3f2>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler (MediaBrowser.Model.Services.IRequest httpReq, System.String urlString, System.String host, System.String localPath, System.Threading.CancellationToken cancellationToken) [0x00af1] in <5837600bbe23491d837720283845e3f2>:0 2019-02-24 19:43:51.230 Info HttpServer: HTTP Response 400 to 109.192.243.27. Time: 10ms. http://media.caina.de:8096/emby/Audio/23175/universal?UserId=cf29c9bee8f04205b17d4b8333565b21&DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NTAwMTA5MzQ0Mjk1&MaxStreamingBitrate=700000000&Container=opus,mp3|mp3,aac|aac,m4a|aac,mp4|aac,flac,webma,webm,wav,ogg&TranscodingContainer=ts&TranscodingProtocol=hls&AudioCodec=aac&PlaySessionId=1551033827108&StartTimeTicks=0&EnableRedirection=true&EnableRemoteMedia=false 2019-02-24 19:43:51.235 Info HttpServer: HTTP POST http://media.caina.de:8096/emby/Sessions/Playing. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.238 Info PlaybackReporting - EventMonitorEntryPoint: Adding playback tracker : TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NTAwMTA5MzQ0Mjk1-cf29c9bee8f04205b17d4b8333565b21-42dd0266b463c559863140c384b26f51 2019-02-24 19:43:51.238 Info PlaybackReporting - EventMonitorEntryPoint: PlaybackTracker : Adding Start Event : 2/24/2019 7:43:51 PM 2019-02-24 19:43:51.238 Info PlaybackReporting - EventMonitorEntryPoint: Creating StartPlaybackTimer Task 2019-02-24 19:43:51.239 Info PlaybackReporting - EventMonitorEntryPoint: StartPlaybackTimer : Entered 2019-02-24 19:43:51.239 Info HttpServer: HTTP Response 204 to 109.192.243.27. Time: 4ms. http://media.caina.de:8096/emby/Sessions/Playing 2019-02-24 19:43:51.283 Info HttpServer: HTTP GET http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items/23175. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.287 Info HttpServer: HTTP Response 200 to 109.192.243.27. Time: 4ms. http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items/23175 2019-02-24 19:43:51.336 Info HttpServer: HTTP POST http://media.caina.de:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.337 Info HttpServer: HTTP GET http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items?SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Audio&Limit=24&Recursive=true&Fields=PrimaryImageAspectRatio%2CCanDelete&Filters=IsPlayed&ParentId=856f63504c187f820893a8f061515aaa&ImageTypeLimit=1&EnableImageTypes=Primary&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.337 Info HttpServer: HTTP GET http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items?SortBy=PlayCount&SortOrder=Descending&IncludeItemTypes=Audio&Limit=24&Recursive=true&Fields=PrimaryImageAspectRatio%2CCanDelete&Filters=IsPlayed&ParentId=856f63504c187f820893a8f061515aaa&ImageTypeLimit=1&EnableImageTypes=Primary&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0 2019-02-24 19:43:51.341 Info HttpServer: HTTP Response 200 to 109.192.243.27. Time: 4ms. http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items?SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Audio&Limit=24&Recursive=true&Fields=PrimaryImageAspectRatio%2CCanDelete&Filters=IsPlayed&ParentId=856f63504c187f820893a8f061515aaa&ImageTypeLimit=1&EnableImageTypes=Primary&EnableTotalRecordCount=false 2019-02-24 19:43:51.341 Info SessionManager: Playback stopped reported by app Emby Mobile 4.0.2.0 playing swr3. Stopped at 0 ms 2019-02-24 19:43:51.343 Info HttpServer: HTTP Response 200 to 109.192.243.27. Time: 5ms. http://media.caina.de:8096/emby/Users/cf29c9bee8f04205b17d4b8333565b21/Items?SortBy=PlayCount&SortOrder=Descending&IncludeItemTypes=Audio&Limit=24&Recursive=true&Fields=PrimaryImageAspectRatio%2CCanDelete&Filters=IsPlayed&ParentId=856f63504c187f820893a8f061515aaa&ImageTypeLimit=1&EnableImageTypes=Primary&EnableTotalRecordCount=false 2019-02-24 19:43:51.344 Info PlaybackReporting - EventMonitorEntryPoint: Playback stop tracker found, processing stop : TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NTAwMTA5MzQ0Mjk1-cf29c9bee8f04205b17d4b8333565b21-42dd0266b463c559863140c384b26f51 2019-02-24 19:43:51.344 Info PlaybackReporting - EventMonitorEntryPoint: PlaybackTracker : Adding Stop Event : 2/24/2019 7:43:51 PM 2019-02-24 19:43:51.344 Info PlaybackReporting - EventMonitorEntryPoint: Playback stop but TrackedPlaybackInfo not found! not storing activity in DB 2019-02-24 19:43:51.344 Info HttpServer: HTTP Response 204 to 109.192.243.27. Time: 8ms. http://media.caina.de:8096/emby/Sessions/Playing/Stopped 2019-02-24 19:43:58.141 Info HttpServer: HTTP GET http://media.caina.de:8096/embywebsocket?deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzcyLjAuMzYyNi45NiBTYWZhcmkvNTM3LjM2fDE1NDk5MjY1Mzk3MDQ1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.109 Safari/537.36 2019-02-24 19:43:58.141 Error HttpServer: Could not find handler for /embywebsocket Edited February 24, 2019 by CChris
renecd 4 Posted October 8, 2021 Posted October 8, 2021 (edited) Came across this thread searching for a way to add my favorite web radio to Emby. It's the RTBF Classic 21 (classic rock) radio. The stream apparently only exist as an ACC stream: https://radios.rtbf.be/classic21-64.aac - at least I'm unable to find any other type. Anyway, it works in a browser and I was also able to add it as a stream to my Volumio player, but when I add it in a .strm file I get the same playback error someone reported with .pls files. Is this more than just allowing an .aac extension in .strm files? Edited October 8, 2021 by renecd
Carlo 4561 Posted October 9, 2021 Posted October 9, 2021 Hi, try installing the IPTV plugin from the catalog if you don't have it setup already. I was able to add this link https://radios.rtbf.be/classic21-64.aac to it and it would playback just fine in Emby. Let me know how you make out. 1
