jamesthomas 0 Posted December 11, 2018 Posted December 11, 2018 Hello, I am running emby server in ubuntu and i am experiencing high RAM usage from emby. I have 128gb ram and emby seems to using it all until the server crash Please check my logs and screenshots attached to find an ideal solution from you Plugins i am running- IPTV plugin I am not transcoding streams doing DIRECT STREAMING ALL SSD logs.zip
Luke 42246 Posted December 11, 2018 Posted December 11, 2018 Hi, this should be improved with the upcoming 3.6 release. Thanks !
jamesthomas 0 Posted December 11, 2018 Author Posted December 11, 2018 Hi, this should be improved with the upcoming 3.6 release. Thanks ! Hi any update when it will be released? or any beta version? i can install a beta version until then
Luke 42246 Posted December 11, 2018 Posted December 11, 2018 Hopefully soon. Yes the beta release is up on the website. Thanks.
jamesthomas 0 Posted December 12, 2018 Author Posted December 12, 2018 (edited) Hopefully soon. Yes the beta release is up on the website. Thanks. Hi Luke, Just to update you & everyone else who have this same issue I have managed to install the beta version 3.6 and its working fine until now. i will report back if this change Amazing work on the 3.6 version thanks luke! Edited December 12, 2018 by jamesthomas
