williamray507 1 Posted April 22, 2014 Posted April 22, 2014 (edited) I have been getting the following error on the dashboard "Log file cleanup failed Access to the path "%AppData%\MediaBrowser-Server\logs\Old Logs" is denied." and when I manually check that folder there is nothing in it at all. Also I can not add/change a password for any user now. I am running Version 3.0.5224.26796 on Windows Server 2012 R2 Essentials. server-63533660892.txt Edited April 21, 2014 by williamray507
Luke 42178 Posted April 22, 2014 Posted April 22, 2014 Welcome. Please provide a little more info and we'll be happy to help. http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/
williamray507 1 Posted April 23, 2014 Author Posted April 23, 2014 Welcome. Please provide a little more info and we'll be happy to help. http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ Attached the info requested.
williamray507 1 Posted April 23, 2014 Author Posted April 23, 2014 sorry but i don't see anything in that log related to the problem you're reporting. perhaps try and find the log from the time the error occurred. Ok so I just tried creating a user named TempUser and then go in and try to create a password, from the logs (too big to upload, https://www.dropbox.com/s/6u8a2wmzqk5tbcd/server-63533807999.txt) I see this: 2014-04-23 19:15:41.3683 Info - UserManager: Authentication request for TempUser has been denied. 2014-04-23 19:15:41.3683 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Invalid user or password entered. System.UnauthorizedAccessException at MediaBrowser.Api.UserService.Post(UpdateUserPassword request) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceExec`1.<>c__DisplayClass6.<CreateExecFn>b__5(Object service, Object request) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2014-04-23 19:15:41.3683 Error - HttpServer: Error processing request for /mediabrowser/Users/0c2eb7dab9650f421fff8f02754ac57c/Password Invalid user or password entered. ServiceStack.HttpError No Stack Trace Available 2014-04-23 19:15:41.3995 Error - ListenerResponse: Could not WriteTextToResponse: Cannot access a disposed object.. Object name: 'System.Net.HttpListenerResponse'. Cannot access a disposed object. Object name: 'System.Net.HttpListenerResponse'. System.ObjectDisposedException at System.Net.HttpListenerResponse.CheckDisposed() at System.Net.HttpListenerResponse.set_ContentLength64(Int64 value) at ServiceStack.Host.HttpListener.ListenerResponse.Write(String text)
Luke 42178 Posted April 24, 2014 Posted April 24, 2014 sorry but i don't see anything in that log related to the problem you're reporting. perhaps try and find the log from the time the error occurred.
Luke 42178 Posted April 27, 2014 Posted April 27, 2014 Can you spell out the steps to reproduce the problem? I tested creating a password and didn't see any issue.
williamray507 1 Posted April 27, 2014 Author Posted April 27, 2014 Can you spell out the steps to reproduce the problem? I tested creating a password and didn't see any issue. I logged into the dashboard, Click Users, CLick Add User, give it a name, uncheck Allow the user to manage the server, check allow media playback, click save, click the user from the list, click password, type the password, confirm it, click save, then the error comes up :Invalid User or Password entered. 1
williamray507 1 Posted April 27, 2014 Author Posted April 27, 2014 Also logging out as myself and clicking the user i just created just logs right in without asking for a password, and i get the same message when tring to create a password when logged into the user account.
Luke 42178 Posted April 27, 2014 Posted April 27, 2014 what browser? keep in mind the login page will never ask for a password if you're on localhost
williamray507 1 Posted April 27, 2014 Author Posted April 27, 2014 what browser? keep in mind the login page will never ask for a password if you're on localhost Tried Firefox and Chrome, im not accessing from the local machine, i am accessing from my desktop.
TonkaTuff 10 Posted April 30, 2014 Posted April 30, 2014 (edited) Hi. I've also recently started seeing a log file cleanup error in my notifications. Log file cleanup failed. 3 minutes ago Access to the path 'C:\Users\spider\AppData\Roaming\MediaBrowser-Server\logs\old' is denied. I'm running Server Version 3.0.5231.40980 Edited April 30, 2014 by TonkaTuff
williamray507 1 Posted April 30, 2014 Author Posted April 30, 2014 Hi. I've also recently started seeing a log file cleanup error in my notifications. I'm running Server Version 3.0.5231.40980 Are you able to create/change passwords for users?
TonkaTuff 10 Posted May 2, 2014 Posted May 2, 2014 Are you able to create/change passwords for users? yep, doesn't seem to be any problem with that.
williamray507 1 Posted May 20, 2014 Author Posted May 20, 2014 One more update, If i create a user on the windows 7 install and shut it down, then copy the users.db & userdata_v2.db from C:\Users\USERNAME\AppData\Roaming\MediaBrowser-Server\data and the user folder from C:\Users\USERNAME\AppData\Roaming\MediaBrowser-Server\config\users over to the server version and start it back up on the server the new users are there and works fine.
williamray507 1 Posted May 21, 2014 Author Posted May 21, 2014 Well to add some more information, I installed the latest dev version on my desktop running windows 7 with the same user as i have it running on on my server updated the verson on the server to match the latest, shut them both down renamed the old install folders on the server and copied over everything from the windows 7 machine and i still get the same error when tring to add users passwords.
