Iluyha89 0 Posted December 10, 2018 Posted December 10, 2018 (edited) Hello, I use Emby for DLNA Before I used previous version 3.4.1.0, and all worked well until I updated my Chrome and scroll stopped work there. So I decided update to 3.5.3.0, and after this always see this error in my logs (attached to the topic). Emby server began to freeze until will be restarted manually (in process list - opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb). Maybe I missed up similar topics. Could you help please with current problem. Edited December 10, 2018 by Iluyha89
Luke 42246 Posted December 11, 2018 Posted December 11, 2018 Hi there, can you please attach the emby server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
Iluyha89 0 Posted December 11, 2018 Author Posted December 11, 2018 (edited) Hello,Found that it was similar topic here https://emby.media/community/index.php?/topic/65402-emby-server-crashing-on-raspberry-pi/I made degrade to 3.4.1.0 back and will follow your next updates.Thank you embyserver-63680061708.txt Edited December 11, 2018 by Iluyha89
Luke 42246 Posted December 11, 2018 Posted December 11, 2018 Hi, this is all you have in the log? it's very short. I suppose you can downgrade to 3.4.1. You could also try the 3.6 beta if you wish. We'll be happy to help with any problems you have on that. Thanks.
