emmettf 12 Posted December 9, 2018 Posted December 9, 2018 Hi. I've been using emby now for about a year on kodi (currently Leia beta 5) on Xbox without a problem. I just bought a new pc and reinstalled emby server. I installed emby again on the xbox kodi and when it starts I get a message asking if I want to resume previous sync. When I click on yes I get an error message saying something went wrong. Any help would be appreciated. Log: https://paste.kodi.tv/azavupopoz I can connect to the server and play movies when I go through the add-on. Emby v. 3.1.35a
d90 11 Posted December 9, 2018 Posted December 9, 2018 I'm having the same issue on 3.1.35a with multiple OS's and Leia. I suspect this may require waiting for the next version of the beta.
Angelblue05 4132 Posted December 9, 2018 Posted December 9, 2018 Thanks for reporting. I will correct this and ping you when to retry.
Angelblue05 4132 Posted December 9, 2018 Posted December 9, 2018 It should work now. Thanks for making me aware of the situation.
d90 11 Posted December 10, 2018 Posted December 10, 2018 It should work now. Thanks for making me aware of the situation. What's the fix? Is there an update we should look for? 1
Angelblue05 4132 Posted December 10, 2018 Posted December 10, 2018 (edited) Just try to install again. It was my bad, I forgot to push the leia-beta branch, so it couldn’t find the build for emby for kodi to make it work with your Kodi. However you should still consider updating to RC. Edited December 10, 2018 by Angelblue05
