Oracle 86 Posted December 9, 2018 Posted December 9, 2018 Unsure why, whether it be the settings of my DVD ripper, my television, or something inside Emby's settings, but often times, the audio of pretty much every file has some sort of issue where the dialogue is suppressed, but the background noise (shooting, explosions, whatever) is much louder and can be heard clearly at a regular volume. I have been forced to turn my television's volume settings up to even hear the dialogue. Is this an Emby issue, can I change this? How?
Luke 42216 Posted December 9, 2018 Posted December 9, 2018 Hi there, can we look at an example of how you're playing? Please attach the information requested in how to report a media playback issue. thanks !
Oracle 86 Posted December 9, 2018 Author Posted December 9, 2018 Sure! Here is the log from the web app: [Attached] Not really sure how else to describe the issue rather than above, and there isn't necessarily a way to provide screen grabs. The volume is regularly on 15-25 while watching standard TV. With Emby, I have it cranked up to at least 35-45 minimum to hear dialogue. Now, it is not the receiver in which Emby is played on, as this issue occurs across multiple platforms (Xbox One, PS4, DLNA, etc.) If you need any further clarification, I'd be happy to try my best and provide it for you. @@Luke Emby Log.txt
Oracle 86 Posted December 9, 2018 Author Posted December 9, 2018 If the log I provided you is not good enough, I have provided below an alternative log from the same time frame. Alternative Emby Log.txt
Oracle 86 Posted December 9, 2018 Author Posted December 9, 2018 This is everything I have available: https://gyazo.com/ac19056739c1d48b979804618db6ef29
Luke 42216 Posted December 9, 2018 Posted December 9, 2018 Ok i'm really looking for a whole folder of logs, what i'm really looking for is to go over one specific example. thanks.
Oracle 86 Posted December 9, 2018 Author Posted December 9, 2018 Where would I find an entire folder of logs? Appdata in file explorer?
Guest asrequested Posted December 9, 2018 Posted December 9, 2018 Looking at that screenshot (no ffmpeg log), it looks like the downmixing from surround sound is not working, for some reason. 1
Solution Oracle 86 Posted December 9, 2018 Author Solution Posted December 9, 2018 I seemed to have fixed the issue after tweaking my sound settings in my TV a little bit more. My wife pointed out to me that it is only the one device that does this, I was mistaken.
