schamane 20 Posted December 7, 2018 Posted December 7, 2018 (edited) when i start with strace i can see the error stat("/opt/emby-server/system/EmbyServer.pdb", 0x7fff9ca7d9b0) = -1 ENOENT (No such file or directory) lstat("/opt/emby-server/system/EmbyServer.pdb", 0x7fff9ca7d9c0) = -1 ENOENT (No such file or directory) flock(49, LOCK_UN) = 0 close(49) = 0 mprotect(0x7fcb48030000, 65536, PROT_READ|PROT_WRITE) = 0 write(7, "System.DllNotFoundException: Una"..., 538System.DllNotFoundException: Unable to load shared library 'sqlite3' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: libsqlite3: cannot open shared object file: No such file or directory at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_libversion_number() at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number() at SQLitePCL.raw.SetProvider(ISQLite3Provider imp) at EmbyServer.Program.Main(String[] args)) = 538 I have no pdb file at all at any emby directory edit: BTW was there done something in recognizing movies? Cause Emby doesn`t recognize Movies anymore which it did before edit2: even 3.6.0.72 which is the oldest version i can load is broken, so I have no working emby at the moment Edited December 7, 2018 by schamane
schamane 20 Posted December 7, 2018 Author Posted December 7, 2018 DISTRIB_ID=Ubuntu DISTRIB_RELEASE=16.04 DISTRIB_CODENAME=xenial DISTRIB_DESCRIPTION="Ubuntu 16.04.5 LTS"
schamane 20 Posted December 7, 2018 Author Posted December 7, 2018 ok, i just recognized taht sqlite3 wasnt installed, now it is installed, but no change Is it possible I need some -dev package or other dependencies?
alucryd 318 Posted December 7, 2018 Posted December 7, 2018 sqlite3 is provided in our package and should automatically be used by emby. How are you starting emby?
schamane 20 Posted December 10, 2018 Author Posted December 10, 2018 hi, sorry was busy whole weekend. my start parameter looks like this strace /opt/emby-server/system/EmbyServer -programdata /var/lib/emby-server -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb all folders and files are existent when i downgrade to 3.5.3.0 its working again when i do a ps axfwww i see a defference /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb so i tried strace /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb same result mmap(NULL, 65536, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f3855509000 mprotect(0x7f3855509000, 65536, PROT_READ|PROT_WRITE) = 0 munmap(0x7f3855509000, 65536) = 0 mprotect(0x7f37e19cf000, 4096, PROT_READ|PROT_WRITE) = 0 mprotect(0x7f37e19cf000, 4096, PROT_READ|PROT_WRITE|PROT_EXEC) = 0 lseek(49, 358904, SEEK_SET) = 358904 read(49, "RSDS\3305\23\227\342\216eN\251y\271^[\347\376\372\1\0\0\0/home/em"..., 4096) = 4096 mprotect(0x7f37e23e4000, 4096, PROT_READ|PROT_WRITE) = 0 stat("/opt/emby-server/system/EmbyServer.pdb", 0x7ffd5d8dc250) = -1 ENOENT (No such file or directory) lstat("/opt/emby-server/system/EmbyServer.pdb", 0x7ffd5d8dc260) = -1 ENOENT (No such file or directory) flock(49, LOCK_UN) = 0 close(49) = 0 mprotect(0x7f37bc030000, 65536, PROT_READ|PROT_WRITE) = 0 write(7, "System.DllNotFoundException: Una"..., 538System.DllNotFoundException: Unable to load shared library 'sqlite3' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: libsqlite3: cannot open shared object file: No such file or directory at SQLitePCL.SQLite3Provider_sqlite3.NativeMethods.sqlite3_libversion_number() at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number() at SQLitePCL.raw.SetProvider(ISQLite3Provider imp) at EmbyServer.Program.Main(String[] args)) = 538 write(7, "\n", 1 ) = 1 gettid() = 2844 unlink("/tmp/clr-debug-pipe-2844-92145608-in") = 0 unlink("/tmp/clr-debug-pipe-2844-92145608-out") = 0 write(4, "\3", 1) = 1 rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0 tgkill(2844, 2844, SIGABRT) = 0 --- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=2844, si_uid=0} --- +++ killed by SIGABRT (core dumped) +++
Luke 42246 Posted December 10, 2018 Posted December 10, 2018 Why are you starting the server with your own command line?
schamane 20 Posted December 10, 2018 Author Posted December 10, 2018 Cause if I do not use strace, I don`t get any output, it just crashes
schamane 20 Posted December 10, 2018 Author Posted December 10, 2018 anyways, i downgraded now to 3.5.3 and had to rebuild database for it, so i will stick on stable
Luke 42246 Posted December 10, 2018 Posted December 10, 2018 Cause if I do not use strace, I don`t get any output, it just crashes So that's something we should look at then, about why you need to use that.
