701h 12 Posted December 5, 2018 Posted December 5, 2018 (edited) I've been using the NextPVR plugin for a while now, and while it mostly works fine, the one annoying thin that keeps getting me, it that if I rewind of fast forward too far (ie past the start or end of the buffer), the thing seem to hang, and I have to quit out Emby. Obviously when I restart, I've lost the buffer of what I was watching. Since I have a hauppauge tuner that Emby can detect, I've thought about moving away from NextPVR, and using the Emby DVR option, however that means I need a TV guide supplier. I find this very silly, but that's beside the point. Since I have NextPVR already getting the TV guide OTA, can I somehow get Emby to pull the TV guide from NextPVR? thanks. Rich Edited December 5, 2018 by 701h
SHSPVR 125 Posted December 6, 2018 Posted December 6, 2018 (edited) If you Purchase the Emby Premiere you will have with Schedules Direct right now but if you have been pay attn to news with Emby ver 3.6 the Live TV Guide Data will be Included with Premiere so more need of Schedules Direct Is that with LiveTV that your having problem with ?. Edited December 6, 2018 by SHSPVR
701h 12 Posted December 6, 2018 Author Posted December 6, 2018 yes Live TV guide. Is it possible to get the TV guide from NextPVR or WinTV? Both of these get get the TV guide OTA. You dont get Schedules Direct with Premiere, as far as I'm aware, you have to pay for Schedules Direct separately. Live TV guide is not included in Emby 3.6 if you live in Australia.
arrbee99 1836 Posted December 6, 2018 Posted December 6, 2018 Far as I know, which isn't much, you can't use NextPVR and its plugin to provide data to TV provided by another method, such as the built in Emby Hauppauge tuner feature. Doesn't Hauppauge provide a guide ? not sure if you've tried it. Think you need to install WinTV for it to work, but not sure. Alternatively you could maybe get an xmltv guide, such as mentioned here - https://www.matthuisman.nz/2017/08/kodi-freeview-au-iptv-setup-with-full-guide.html and map the channels (if necessary).
701h 12 Posted December 7, 2018 Author Posted December 7, 2018 Thanks. That worked a treat. I just connected the xmltv to the xml link in that guide and got most of my channels. Sent from my SM-G935F using Tapatalk 1
SHSPVR 125 Posted December 7, 2018 Posted December 7, 2018 (edited) yes Live TV guide. Is it possible to get the TV guide from NextPVR or WinTV? Both of these get get the TV guide OTA. You dont get Schedules Direct with Premiere, as far as I'm aware, you have to pay for Schedules Direct separately. Live TV guide is not included in Emby 3.6 if you live in Australia. That not what I meant 701h If you have Premiere and you have Schedules Direct account and your WinTV device you don't need NextPVR to get the Guide As I said with Emby ver 3.6 when with come out it will have it own Guide data directly from grace note See Click on Link Edited December 7, 2018 by SHSPVR
