EODCrafter 181 Posted January 2, 2019 Posted January 2, 2019 (edited) after a bit of googling and then looking at the 3.6 blog post about switching to gracenotes from scheduletv. which is what i assume you are referring to. which I am not able to update to 3.6 yet. Okay, Good Luck with Vaders, and the 100 others that have reported this! Like I said, their stance is all should conform to their File. Edited January 2, 2019 by EODCrafter 1
robesau 1 Posted January 2, 2019 Posted January 2, 2019 Okay, Good Luck with Vaders, and the 100 others that have reported this! yah I am just going to ignore it as vaders already said they wouldnt help cause they dont support emby. i will wait till i can upgrade to emby 3.6 and use the new guide. also how the hell do you function with a background picture of static. I almost went blind just seeing it in the screen shot hahahaha. 1
EODCrafter 181 Posted January 2, 2019 Posted January 2, 2019 (edited) yah I am just going to ignore it as vaders already said they wouldnt help cause they dont support emby. i will wait till i can upgrade to emby 3.6 and use the new guide. also how the hell do you function with a background picture of static. I almost went blind just seeing it in the screen shot hahahaha. IKR, that's weird it just screen shots like that BTW Why can't you Upgrade to the Beta Version? JC.... Edited January 2, 2019 by EODCrafter
pir8radio 1313 Posted January 3, 2019 Posted January 3, 2019 vaders xml worked for me just fine... I only switched to iptv-epg.com due to vaders horrible EPG uptime.. iptv-epg.com also includes way more show photos and better channel logos.
EODCrafter 181 Posted January 3, 2019 Posted January 3, 2019 (edited) vaders xml worked for me just fine... I only switched to iptv-epg.com due to vaders horrible EPG uptime.. iptv-epg.com also includes way more show photos and better channel logos. Users have reported on xTeVe for 3 days now the file contains Invalid characters which makes it a Invalid XML. I.E. & instead of & or whatever the format is. 2019/01/01 04:27:36 [xTeVe] [ERROR] XML syntax error on line 231337: invalid character entity & (no semicolon) - 2019/01/01 04:27:36 [xTeVe] [ERROR] XEPG requires an XMLTV file - Here's a fix a user has reported...... #!/bin/sh curl -S 'http://vapi.vaders.tv/epg/vget?username={USERNAME}password={PASSWORD}&format=ts' --output vaders.m3u curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET http://vaders.tv/p2.xml > vaders-temp.xml sed -e 's/&[^amp;|^apos;|^quot;|^lt;|^gt;]/&/gi' vaders-temp.xml > vaders.xml sed -i 's/\ß//g' vaders.xml sed -i 's/\& amp;/\&/g' vaders.xml rm -f vaders-temp.xml Edited January 3, 2019 by EODCrafter 1
