ginjaninja 605 Posted October 2, 2024 Posted October 2, 2024 On 25/09/2024 at 04:59, hatharry said: Playlist support has been updated, this should be released in the next couple of days. Until amazon supports playlists for multiple languages, I suggest naming the playlist a single word e.g. "Rock", "Chill" I am still getting "sorry i am having trouble accessing your Emby skill right now".. the log shows the skill submitted the correct search and a response was given
Luke 42239 Posted October 20, 2024 Posted October 20, 2024 On 10/2/2024 at 11:57 AM, ginjaninja said: I am still getting "sorry i am having trouble accessing your Emby skill right now".. the log shows the skill submitted the correct search and a response was given Hi, can you try this again? Are you still seeing this? Thanks.
ginjaninja 605 Posted October 21, 2024 Posted October 21, 2024 (edited) 12 hours ago, Luke said: Hi, can you try this again? Are you still seeing this? Thanks. Sure , I get "i encountered a glitch, can you say that again", but the playlist is searched for and found it seems. 2024-10-21 09:01:23.999 Info Server: http/1.1 Response 204 to 54.82.149.109. Time: 1ms. POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full 2024-10-21 09:01:24.025 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=85c51e9e-c5ca-4e70-93ab-b84e0cfc0ae2. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.027 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 2ms. GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=85c51e9e-c5ca-4e70-93ab-b84e0cfc0ae2 2024-10-21 09:01:24.306 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=dfd5475cb19b1e1061a4f9db6747d04c. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.307 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 1ms. GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=dfd5475cb19b1e1061a4f9db6747d04c 2024-10-21 09:01:24.682 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=SortName&IncludeItemTypes=Playlist&Recursive=true&SearchTerm=car. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.696 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 14ms. GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=SortName&IncludeItemTypes=Playlist&Recursive=true&SearchTerm=car 2024-10-21 09:01:24.986 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=ListItemOrder&IncludeItemTypes=Audio&Recursive=true&ParentId=290177. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.988 Debug SqliteItemRepository: GetitemById Playlist 290177 C:\Users\username\AppData\Roaming\Emby-Server\programdata\data\userplaylists\Car [playlist]\Car.m3u 2024-10-21 09:01:25.415 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 429ms. GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=ListItemOrder&IncludeItemTypes=Audio&Recursive=true&ParentId=290177 2024-10-21 09:01:34.017 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Connect/Exchange?ConnectUserId=165. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:34.017 Debug AuthenticationRepository: GetInternalId reportedDeviceId: dfd5475cb19b1e1061a4f9db6747d04c 2024-10-21 09:01:34.017 Info SessionManager: Reissuing access token: c57bf79b07474f5fb96791a5d78a78ce 2024-10-21 09:01:34.018 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 1ms. GET https://xxx.xxx.xxx:8920/emby/Connect/Exchange?ConnectUserId=165 2024-10-21 09:01:34.576 Info Server: http/1.1 POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:34.576 Debug AuthenticationRepository: UpdateCapabilities id: 117 2024-10-21 09:01:34.577 Info Server: http/1.1 Response 204 to 54.82.149.109. Time: 1ms. POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full edit it is a large playlist 1200 tracks, testing on swagger the browser timesout; it takes a good 10 seconds to return the playlist members. Will try will a smaller playlist edit Bingo smaller playlist works as an aside...and as mentioned by @hatharrythe skill is very (too imo) sensitive for the name search. Not sure what affects alexa accuracy at picking up command words ...would [play] [list] "Rock" be more reliable than [play] [playlist] "rock"? i couldnt get a name of "test" to work....i got name="Rock" to work 2024-10-21 09:16:21.922 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?IncludeItemTypes=Movie&SortBy=DateCreated&SortOrder=Descending&Recursive=true&SearchTerm=Playlist test&ExcludeLocationTypes=Virtual&Limit=50. Source Ip: 54.147.128.102, UserAgent: node-fetch Edited October 21, 2024 by ginjaninja 1
hatharry 113 Posted October 22, 2024 Posted October 22, 2024 (edited) 18 hours ago, ginjaninja said: Sure , I get "i encountered a glitch, can you say that again", but the playlist is searched for and found it seems. 2024-10-21 09:01:23.999 Info Server: http/1.1 Response 204 to 54.82.149.109. Time: 1ms. POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full 2024-10-21 09:01:24.025 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=85c51e9e-c5ca-4e70-93ab-b84e0cfc0ae2. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.027 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 2ms. GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=85c51e9e-c5ca-4e70-93ab-b84e0cfc0ae2 2024-10-21 09:01:24.306 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=dfd5475cb19b1e1061a4f9db6747d04c. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.307 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 1ms. GET https://xxx.xxx.xxx:8920/emby/Sessions?DeviceId=dfd5475cb19b1e1061a4f9db6747d04c 2024-10-21 09:01:24.682 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=SortName&IncludeItemTypes=Playlist&Recursive=true&SearchTerm=car. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.696 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 14ms. GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=SortName&IncludeItemTypes=Playlist&Recursive=true&SearchTerm=car 2024-10-21 09:01:24.986 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=ListItemOrder&IncludeItemTypes=Audio&Recursive=true&ParentId=290177. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:24.988 Debug SqliteItemRepository: GetitemById Playlist 290177 C:\Users\username\AppData\Roaming\Emby-Server\programdata\data\userplaylists\Car [playlist]\Car.m3u 2024-10-21 09:01:25.415 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 429ms. GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?SortBy=ListItemOrder&IncludeItemTypes=Audio&Recursive=true&ParentId=290177 2024-10-21 09:01:34.017 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Connect/Exchange?ConnectUserId=165. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:34.017 Debug AuthenticationRepository: GetInternalId reportedDeviceId: dfd5475cb19b1e1061a4f9db6747d04c 2024-10-21 09:01:34.017 Info SessionManager: Reissuing access token: c57bf79b07474f5fb96791a5d78a78ce 2024-10-21 09:01:34.018 Debug Server: http/1.1 Response 200 to 54.82.149.109. Time: 1ms. GET https://xxx.xxx.xxx:8920/emby/Connect/Exchange?ConnectUserId=165 2024-10-21 09:01:34.576 Info Server: http/1.1 POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full. Source Ip: 54.82.149.109, UserAgent: node-fetch 2024-10-21 09:01:34.576 Debug AuthenticationRepository: UpdateCapabilities id: 117 2024-10-21 09:01:34.577 Info Server: http/1.1 Response 204 to 54.82.149.109. Time: 1ms. POST https://xxx.xxx.xxx:8920/emby/Sessions/Capabilities/Full edit it is a large playlist 1200 tracks, testing on swagger the browser timesout; it takes a good 10 seconds to return the playlist members. Will try will a smaller playlist edit Bingo smaller playlist works as an aside...and as mentioned by @hatharrythe skill is very (too imo) sensitive for the name search. Not sure what affects alexa accuracy at picking up command words ...would [play] [list] "Rock" be more reliable than [play] [playlist] "rock"? i couldnt get a name of "test" to work....i got name="Rock" to work 2024-10-21 09:16:21.922 Debug Server: http/1.1 GET https://xxx.xxx.xxx:8920/emby/Users/6cc6d0fa039849af8147592f5da46188/Items?IncludeItemTypes=Movie&SortBy=DateCreated&SortOrder=Descending&Recursive=true&SearchTerm=Playlist test&ExcludeLocationTypes=Virtual&Limit=50. Source Ip: 54.147.128.102, UserAgent: node-fetch [play] [playlist] "rock" is more reliable than [play] [list] "Rock" to avoid the double "play" try saying "play the playlist rock" Edited October 22, 2024 by hatharry 1
