troyhough 61 Posted December 11, 2018 Author Posted December 11, 2018 (edited) Isn't a visual buffer indicator along the progress bar the more common pattern? That's how it is now, right? I don't want that to go away, however, would like the additional option that was discussed above. You can't tell how much is loaded the current way if there's only 5 or 40 seconds. It's nice to see, for instance, if you're In BFE, in spotty cell coverage what you have buffered. It's the first thing I noticed when switching from Plex to Emby and thought it was so cool. Then, I paid for a schedulesdirect subscription, and it went away :'( Edited December 12, 2018 by troyhough
Luke 42246 Posted December 12, 2018 Posted December 12, 2018 Ok I understand thanks. We will have a new app update soon. Please retry the buffer indicator then. Thanks. 1
troyhough 61 Posted December 12, 2018 Author Posted December 12, 2018 (edited) Ok I understand thanks. We will have a new app update soon. Please retry the buffer indicator then. Thanks. Thanks! You ROCK @@Luke. It's the little things that matter! Edited December 12, 2018 by troyhough
troyhough 61 Posted December 19, 2018 Author Posted December 19, 2018 Ok I understand thanks. We will have a new app update soon. Please retry the buffer indicator then. Thanks. Hi Luke, Checked the new 3.0.24 and don't see anything different. Do you know if something was implemented?
Detail4687 4 Posted September 29, 2019 Posted September 29, 2019 @@Luke so we're supposed to be able to see how much has buffered? Such as in a YouTube video?
troyhough 61 Posted September 29, 2019 Author Posted September 29, 2019 @@Luke so we're supposed to be able to see how much has buffered? Such as in a YouTube video? Yes that is correct.
Detail4687 4 Posted September 29, 2019 Posted September 29, 2019 Yes that is correct. Can you tell where the setting is to enable that, cause I don't see this on chrome, Roku not android
troyhough 61 Posted September 29, 2019 Author Posted September 29, 2019 Can you tell where the setting is to enable that, cause I don't see this on chrome, Roku not android It's enabled by default. This is Chrome on the PC.
Luke 42246 Posted September 30, 2019 Posted September 30, 2019 Correct, the apps that have this, don't require anything to enable it.
