ciro80 12 Posted December 4, 2018 Posted December 4, 2018 Version emby-server-deb_3.6.0.74_amd64.deb S.o. Linux ubuntu 4.4.0-116-generic #140-Ubuntu SMP Mon Feb 12 21:23:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux Plugin : IPTV 1.1.6 rtsp : rtsp://admin:password123@192.168.1.70 Problem : not start stream LOG: 10","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"51","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"External"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":true,"AutoOpenLiveStream":true,"DirectPlayProtocols":["Http"]} 2018-12-04 10:14:50.208 Debug App: Running FFProbeProvider for test1 2018-12-04 10:14:50.220 Info MediaEncoder: Ffprobe -analyzeduration 3000000 -i "rtsp://admin:password123@192.168.1.70" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2018-12-04 10:14:50.220 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -analyzeduration 3000000 -i "rtsp://admin:password123@192.168.1.70" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2018-12-04 10:14:50.228 Info MediaEncoder: ProcessRun 'ffprobe' Started. 2018-12-04 10:14:50.321 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 1 2018-12-04 10:14:50.346 Error App: Error in ffprobe *** Error Report *** Version: 3.6.0.74 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: ffprobe failed for "rtsp://admin:password123@192.168.1.70" - streams and format are both null: { } ffprobe version 4.0.2-emby_2018_11_21 Copyright © 2007-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --cc=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-vdpau --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-libsmbclient --enable-cuda --enable-cuvid --enable-libmfx --enable-nvenc --enable-vaapi --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --extra-libs='-lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -luuid -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [rtsp @ 0x10f5780] method DESCRIBE failed: 401 Unauthorized rtsp://admin:password123@192.168.1.70: Server returned 401 Unauthorized (authorization failed) at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken) 2018-12-04 10:14:50.358 Info App: User policy for Ciro. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2018-12-04 10:14:50.371 Info App: Profile: Unknown Profile, Path: rtsp://admin:password123@192.168.1.70, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-12-04 10:14:50.378 Info App: Profile: Unknown Profile, No direct play profiles found for Path: rtsp://admin:password123@192.168.1.70 2018-12-04 10:14:50.396 Info App: RemoteClientBitrateLimit: 2000000, RemoteIp: 192.168.1.76, IsInLocalNetwork: False 2018-12-04 10:14:50.396 Info App: Profile: Unknown Profile, Path: rtsp://admin:password123@192.168.1.70, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-12-04 10:14:50.396 Info App: Profile: Unknown Profile, No direct play profiles found for Path: rtsp://admin:password123@192.168.1.70 2018-12-04 10:14:50.414 Info App: RemoteClientBitrateLimit: 2000000, RemoteIp: 192.168.1.76, IsInLocalNetwork: False 2018-12-04 10:14:50.422 Info HttpServer: HTTP Response 200 to 192.168.1.76. Time: 252ms. http://192.168.1.86:8096/emby/Items/220054/PlaybackInfo?UserId=7bdf79ca5a2c43b8a73e035217d65ab0&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=840000000 2018-12-04 10:14:50.727 Info HttpServer: HTTP GET http://192.168.1.86:8096/emby/videos/220054/master.m3u8?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzcwLjAuMzUzOC4xMDIgU2FmYXJpLzUzNy4zNnwxNTQzMDk1MDcxNDEz&MediaSourceId=6b1ca0f9cbdb397ff52bed10efda9cb0&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=1808000&AudioBitrate=192000&PlaySessionId=7d395a66c54c480094809fac6aa78347&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&TranscodeReasons
Luke 42246 Posted December 4, 2018 Posted December 4, 2018 Hi there, please attach the complete emby server and ffmpeg log. thanks.
ciro80 12 Posted December 4, 2018 Author Posted December 4, 2018 (edited) logs logs.zip Edited December 4, 2018 by ciro80
Luke 42246 Posted December 4, 2018 Posted December 4, 2018 Your rtsp url returned this: [rtsp @ 0x10f5780] method DESCRIBE failed: 401 Unauthorized rtsp://admin:OUCQKF@192.168.1.70: Server returned 401 Unauthorized (authorization failed)
ciro80 12 Posted December 4, 2018 Author Posted December 4, 2018 I had already seen this mistake. But anyway it does not work. look at the log more down
softworkz 5133 Posted December 4, 2018 Posted December 4, 2018 There was an error happening because the stream could not be detected. The error is fixed, but I'm not sure why stream detection fails..
softworkz 5133 Posted December 4, 2018 Posted December 4, 2018 Just try with the next beta version as soon as it is released.
ciro80 12 Posted December 5, 2018 Author Posted December 5, 2018 (edited) is there a site to download the beta versions? from the emby interface I see only the released versions. thanks, Ciro Edited December 5, 2018 by ciro80
ciro80 12 Posted December 5, 2018 Author Posted December 5, 2018 I try with other ipcam. Not work.New ip cam with 2 different method rtsp://192.168.1.219/11http://192.168.1.219/tmpfs/auto.jpgSame result, no video Log2.zip
ciro80 12 Posted December 7, 2018 Author Posted December 7, 2018 if you need more information to solve please do not hesitate to ask. is the release scheduled?
Luke 42246 Posted December 7, 2018 Posted December 7, 2018 Yes hopefully soon. Please try the newest beta. Thanks.
ciro80 12 Posted December 10, 2018 Author Posted December 10, 2018 Yes hopefully soon. Please try the newest beta. Thanks. Streaming works now. But how come the enabled users do not see the iptv plug-in? Can I name the icon? (eg iptv to babymonitor)
Luke 42246 Posted December 10, 2018 Posted December 10, 2018 Why do you feel they don't see the plugin?
ciro80 12 Posted December 10, 2018 Author Posted December 10, 2018 Why do you feel they don't see the plugin? Because with my user "ciro" see iptv icon for access. With other user non see test.zip
ciro80 12 Posted December 10, 2018 Author Posted December 10, 2018 Did you check their access settings? YES, in the video that I attached I also see the configurations.
Luke 42246 Posted December 10, 2018 Posted December 10, 2018 Thanks for the report. We'll take a look.
