Casting multi-version movies from Android mobile to Fire TV
StewieGreen
When casting a movie (that has more than one version) from an Android to the FireTV the server only plays the default selection.  Is there going to be the ability to choose which version of a movie to cast from the android app?
atomicmoon
Adamstewiegreen, I believe you can achieve this by selecting which version you want to play on the Android device, before casting.
On my image, where it shows, "Directors Cut" I can choose the theatrical release as I have both in the same folder.
It takes a moment for all the options to load on the mobile app, but hopefully all options will load for you as well.
5c0620205bf93_Screenshot_20181204012715.
