Pin4i 0 Posted December 2, 2018 Posted December 2, 2018 Hi, everybody. Did not find a similar question on the forum and created a topic. There is a server on Windows and Emby server installed. How can I change the link from localhost:8096 to localhost:8096/emby ? P.S. sorry for english, I use google translate =)
Luke 42216 Posted December 2, 2018 Posted December 2, 2018 Hi, can you just put the address in your browser address bar?
Happy2Play 9806 Posted December 2, 2018 Posted December 2, 2018 Hi, everybody. Did not find a similar question on the forum and created a topic. There is a server on Windows and Emby server installed. How can I change the link from localhost:8096 to localhost:8096/emby ? P.S. sorry for english, I use google translate =) Why would you do this?
Pin4i 0 Posted December 5, 2018 Author Posted December 5, 2018 (edited) Hello. Sorry for the long answer. Hi, can you just put the address in your browser address bar? oops... its work ... Why would you do this? I have a "home server" on Windows 7 that Emby runs and NextCloud runs on it in VritualBox. NextCloud works on ssl (port 443), Emby has a standard port 8096. The problem is that I can’t access Emby "normally" outside my home network. Here is the address http://megabublik.asuscomm.com:8096 if you go to it the first time, then everything is fine, but if you first go to https://megabublik.asuscomm.com, and then to Emby, then the browser automatically tries to go to https instead of http. And I thought that if I translate all services into http *: // domainName / * ServiceName *, then I can solve the problem. This is not an Emby problem, forgive me for asking a question off-topic, but maybe you know how this can be fixed? P.S. sorry for english, I use google translate =) Edited December 5, 2018 by Pin4i
