djhifi 56 Posted December 1, 2018 Posted December 1, 2018 (edited) After checking this new feature coming in Kodi Leia I would like to know if it's possible to implement also in Emby (and, therefore Emby for Kodi)? Description Added movie version feature With this feature, it's possible to connect more than one video file with one movie entry in library. For example, Kodi will support both STANDARD version and EXTENDED version of a movie live under one movie item. A context menu item "Manage movie version" under "Manage" menu item has been added to the GUI. A "Version" button has also been added to the video info dialog for movie, which allows user change the default video file for the movie. The change will be saved to DB. source: https://github.com/xbmc/xbmc/pull/14972 @@Angelblue05 what you think about this? Edited December 1, 2018 by djhifi
Luke 42216 Posted December 2, 2018 Posted December 2, 2018 Hi there, to learn more about our multi-version movie support, please check out our wiki: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming Thanks !
