unhooked 17 Posted December 17, 2018 Posted December 17, 2018 New guide data seems to be working well, is there a limit to how many localities we can pull from via gracenote? Also, will providing our own continue to be concatenated and merged in the future? The reason I ask is I live near the border and no sources ever have everything I pull in and comet doesn't have an android app so I source that from the web (just nice to see what's on without going in the other room to turn on the roku.)
Luke 42216 Posted December 17, 2018 Author Posted December 17, 2018 There currently is not a limit. Yes you can still continue to use your own sources as well. Thanks. 1
mypanasonic 8 Posted December 18, 2018 Posted December 18, 2018 will they still be a limit on the amount of international providers lists you can select at a time ?
Luke 42216 Posted December 18, 2018 Author Posted December 18, 2018 will they still be a limit on the amount of international providers lists you can select at a time ? What do you mean? A limit where?
mypanasonic 8 Posted December 18, 2018 Posted December 18, 2018 (edited) What do you mean? A limit where? on SD at the moment you can only select either 4-5 providers ie. Sky HD, Virgin, DirecTV, Dish Network etc if you try to add anymore SD says you have gone over your account limit so say on my channels list consists of epix, epix 2 and epixs hits is on Dish Network and the following movie channels are on DirecTV HBO, FOX Movies etc.. then i add Sky for my uk channels and then ViaSat for my nordic movie channels that have English audio. Edited December 18, 2018 by mypanasonic
dcol 176 Posted December 18, 2018 Posted December 18, 2018 This is important to know, because I get IPTV sources from local channels in different areas of the US. ie, some content from Chicago, NY, Fla, LA, etc. The guide data is different, but with SD I can only choose 4 sources. Does Emby allow me to choose more than that so I can get data from different locations?
Luke 42216 Posted December 18, 2018 Author Posted December 18, 2018 I imagine there will have to be some limit, we're just not sure yet what that will be. Thanks.
dcol 176 Posted December 18, 2018 Posted December 18, 2018 (edited) I would be happy with eight. Can't see ever needing more than that with IPTV. A typical setup for me would be to use east and west dish for 100 channels, then local on 6 zip codes using 6-10 channels Edited December 18, 2018 by dcol
murky024 3 Posted December 20, 2018 Posted December 20, 2018 So I am excited to see these upcoming changes. This all looks great and I am glad I didn't renew my SD subscription. I am curious when the estimated timeline for release to production will be?
unhooked 17 Posted December 20, 2018 Posted December 20, 2018 I would be happy with eight. Can't see ever needing more than that with IPTV. A typical setup for me would be to use east and west dish for 100 channels, then local on 6 zip codes using 6-10 channels If you end up needing more, you can use zap2xml to pull a couple of sources utilizing the -J flag to combine them and then feed that to emby. zap2 can pull from tvguide.com and their source. Last time I checked you could even pull anonymously. Or set up one free account for each, and customize your lineups as anon pulls pull everything. 1
doffactory 3 Posted December 29, 2018 Posted December 29, 2018 May I just kindly double-check. If we upgrade to 3.6 we will not be able to go back to 3.5, right? I am curious, what happens if I do NOT want to use gracenote, but I have my own xmltv EPG data? Would it be still possible to import? I see nowhere any info about this. It is especially relevant for me, as I will not be able to downgrade. Premiere user here.
samuelqwe 317 Posted December 29, 2018 Posted December 29, 2018 May I just kindly double-check. If we upgrade to 3.6 we will not be able to go back to 3.5, right? I am curious, what happens if I do NOT want to use gracenote, but I have my own xmltv EPG data? Would it be still possible to import? I see nowhere any info about this. It is especially relevant for me, as I will not be able to downgrade. Premiere user here. XMLTV isn’t going anywhere. I use 3.6 and I can use XMLTV guides just fine. But no, you can’t go back, at least not easily. 2
Senna 368 Posted December 29, 2018 Posted December 29, 2018 @@doffactory What's your Live TV source ? If it is IPTV, than I would advise to keep your current XMLTV EPG data setup as it is now, because Guide data channel mapping in current 3.6 beta, still needs some TLC from Emby Devs to make the transition to Emby Guide data (GN) with IPTV channels user friendly and not a headache. https://emby.media/community/index.php?/topic/65982-new-emby-guide-provider/page-15&do=findComment&comment=668486 Revamped Channel Management appears to be on Emby's roadmap AFTER the 3.6 release, so lets wait and see what future development brings.
kanipek 230 Posted December 29, 2018 Posted December 29, 2018 May I just kindly double-check. If we upgrade to 3.6 we will not be able to go back to 3.5, right? I am curious, what happens if I do NOT want to use gracenote, but I have my own xmltv EPG data? Would it be still possible to import? I see nowhere any info about this. It is especially relevant for me, as I will not be able to downgrade. Premiere user here.The easiest way to go back to a previous version is - - before you update make a backup of the program data and system folders that reside in your emby-server folder. You will have to do a library scan to catch any changes if you go back. I am using XMLTV with 3.6 works just fine. Sent from my SM-N900T using Tapatalk
Luke 42216 Posted December 29, 2018 Author Posted December 29, 2018 Rolling back from 3.6 to 3.5 is not supported due to the scope of the changes. Thanks.
dcol 176 Posted December 29, 2018 Posted December 29, 2018 My suggestion is, if you have IPTV and want to map under 100 channels and have some time to kill. Go for it. Works very nice. Personally I use iptv-epg.com and customize the M3U playlist with only the channels I use. Then it is not so cumbersome. The ultimate goal is to dump all those 'paid' services when Emby has some decent channel management.
doffactory 3 Posted December 30, 2018 Posted December 30, 2018 @@doffactory What's your Live TV source ? If it is IPTV, than I would advise to keep your current XMLTV EPG data setup as it is now, because Guide data channel mapping in current 3.6 beta, still needs some TLC from Emby Devs to make the transition to Emby Guide data (GN) with IPTV channels user friendly and not a headache. https://emby.media/community/index.php?/topic/65982-new-emby-guide-provider/page-15&do=findComment&comment=668486 Revamped Channel Management appears to be on Emby's roadmap AFTER the 3.6 release, so lets wait and see what future development brings. Thanks, this is exactly what I had in mind, however, I was not aware that the xmltv is staying or not. My main reason for emby is indeed the iptv + transcoding functionality, less movies. This is absolutely crucial for me. Thanks everybody for the update. The easiest way to go back to a previous version is - - before you update make a backup of the program data and system folders that reside in your emby-server folder. You will have to do a library scan to catch any changes if you go back. I am using XMLTV with 3.6 works just fine. Sent from my SM-N900T using Tapatalk Thanks for the info, made the necessary backups indeed. This is the safest option one can have. My suggestion is, if you have IPTV and want to map under 100 channels and have some time to kill. Go for it. Works very nice. Personally I use iptv-epg.com and customize the M3U playlist with only the channels I use. Then it is not so cumbersome. The ultimate goal is to dump all those 'paid' services when Emby has some decent channel management. Thanks for the clarification. I would wish for a much better iptv handling in Emby, which would be much more TV-friendly even in a browser window, seeing a list of TV channels, proper EPG listing, etc. At the moment things do work, however, it is sometimes difficult to navigate through 200+ of iptv channels.
notla49285 48 Posted January 3, 2019 Posted January 3, 2019 Can I ask - I want to set up Live TV for the first time now on my server, can I sign up for Schedules Direct or is this now unavailable? Any ideas when 3.6 will be on stable release? I appreciate that development takes time but a little clarification as to where users currently stand would be nice. 1
Spaceboy 2573 Posted January 3, 2019 Posted January 3, 2019 May I just kindly double-check. If we upgrade to 3.6 we will not be able to go back to 3.5, right? I am curious, what happens if I do NOT want to use gracenote, but I have my own xmltv EPG data? Would it be still possible to import? I see nowhere any info about this. It is especially relevant for me, as I will not be able to downgrade. Premiere user here.thats what I do with xteve. I supply a 100% matching m3u and xmltv file from xteve, actually still from schedules direct. It works very well 2
dcol 176 Posted January 3, 2019 Posted January 3, 2019 Looked at xteve. Huge learning curve with a CLI only interface. Gave it up after a few hours of no results. Waste of time in my book.
Spaceboy 2573 Posted January 3, 2019 Posted January 3, 2019 Looked at xteve. Huge learning curve with a CLI only interface. Gave it up after a few hours of no results. Waste of time in my book.[emoji23][emoji1787][emoji2957] you’ve made a fool of yourself there. You spent a few hours on it and didn’t realise the command window is for information only [emoji23][emoji23][emoji23] how thick are you?
dcol 176 Posted January 3, 2019 Posted January 3, 2019 (edited) Really, A bit abusive of a post. Man, I hit a nerve. You got some interest in that piece of garbage? Gave it a valid attempt. Didn't work and didn't like the interface. Never showed any content and had errors pulling in some M3U streams. Had more difficulty than any other M3U program I have used. Not user friendly and a waste of time IMO. Edited January 3, 2019 by dcol
kanipek 230 Posted January 3, 2019 Posted January 3, 2019 (edited) [emoji23][emoji1787][emoji2957] you’ve made a fool of yourself there. You spent a few hours on it and didn’t realise the command window is for information only [emoji23][emoji23][emoji23] how thick are you? Poke fun at others....mature That being said xteve isn't the easiest thing to set up, with basically no documentation. The Discord channel can be of some help - but that too is pretty "different" from typical forum type support. I just wish it worked with the HDHR Prime. Edited January 3, 2019 by kanipek
notla49285 48 Posted January 3, 2019 Posted January 3, 2019 (edited) Really, A bit abusive of a post. Man, I hit a nerve. You got some interest in that piece of garbage? Gave it a valid attempt. Didn't work and didn't like the interface. Never showed any content and had errors pulling in some M3U streams. Had more difficulty than any other M3U program I have used. Not user friendly and a waste of time IMO. Don't waste time on @@Spaceboy trying to justify yourself, report his post and move on. Edited January 3, 2019 by notla49285
