Centory 21 Posted December 1, 2018 Posted December 1, 2018 (edited) Hi, Emby Server version is 3.6.0.73, when i sync the themes with Emby for Kodi 3.1.34a, nothing will happen, no folder with the tvtunes.nfo file will be created in /storage/.kodi/userdata/addon_data/plugin.video.emby/library/. When i downgrade to version 3.0.34, it works normally. And is it possible in the future, when i have a new movie/tvshow, that the theme will also be automatically added to Kodi? It's irritating to sync every movie separately. thanks in advance Edited January 19, 2019 by Centory
Angelblue05 4132 Posted December 1, 2018 Posted December 1, 2018 Provide your Kodi log containing the attempt to sync themes? And yes, it is something I want to support in the future, thank you.
Centory 21 Posted December 1, 2018 Author Posted December 1, 2018 Hi @@Angelblue05, when i'm back at home, i hope tomorrow, i'll post the log. Thank you 1
Centory 21 Posted December 6, 2018 Author Posted December 6, 2018 Hi, also with version 3.1.35a it works not. Now i'm back on 3.0.34 and all works normal with Server-Version 3.6.0.75. And here is the log after resync with version 3.1.35a with native paths. thank you kodi.log
Angelblue05 4132 Posted December 7, 2018 Posted December 7, 2018 @@Centory Looks like the sync worked. So we'll have to dig deeper. Are you able to access your Kodi directory > userdata > addon_data > plugin.video.emby > library. Open one of the tvtunes.nfo files and check the path to the file. Test it, does it work?.Let me know. 1
Centory 21 Posted December 7, 2018 Author Posted December 7, 2018 (edited) Themes from my old movies in the library works, but a new movie will not be added to the library. So, no folder with the moviename and no tvtunes.nfo will be created from a new movie. Edited December 7, 2018 by Centory
Angelblue05 4132 Posted December 8, 2018 Posted December 8, 2018 Yeah the process is not automatic. Rerun the sync theme, does it pick up on the new movies?
Angelblue05 4132 Posted December 8, 2018 Posted December 8, 2018 Ok I understand what you are saying now. I will test on my side and let you know. 1
Centory 21 Posted January 11, 2019 Author Posted January 11, 2019 (edited) Hi @Angelblue05 .This is only for info! With Emby 4.0.0.0 and Emby for Kodi 3.1.39a it also works not. The sync never starts, i think for me it's better to go completely back to version 3.5.3 and Emby for Kodi 3.0.34. Edited January 11, 2019 by Centory
Centory 21 Posted January 17, 2019 Author Posted January 17, 2019 (edited) @Angelblue05 With 3.1.44a is it also not working, when i make a sync, all files (tvtunes.nfo) filled out with <?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <tvtunes /> Edited January 17, 2019 by Centory 1
loomes 40 Posted January 18, 2019 Posted January 18, 2019 I also have Problems with this. Server 4.0.0.2 and Addon 3.1.44. I have deleted the libary dir with all the old tvtunes dirs and nfos and run an update. He created 96 Dirs and says its complete. No error in Logfile. But he must create over 200 Dirs. Then i copy back the backup of the tvunes directorys. All theme Files plays OK. I think there is a bug in the update process. 1
Centory 21 Posted January 18, 2019 Author Posted January 18, 2019 I hope @Angelblue05 can fix this soon.
Angelblue05 4132 Posted January 18, 2019 Posted January 18, 2019 It is still on the list. Thanks for your patience. 1
Angelblue05 4132 Posted January 27, 2019 Posted January 27, 2019 (edited) After some investigation, this is an Emby server issue. The add-on queries from Emby which item has themes, but when trying to retrieve the actual theme, it returns as there being no themes. {u'SoundtrackSongsResult': {u'OwnerId': 0, u'TotalRecordCount': 0, u'Items': []}, u'ThemeSongsResult': {u'OwnerId': 30029, u'TotalRecordCount': 0, u'Items': []}, u'ThemeVideosResult': {u'OwnerId': 30029, u'TotalRecordCount': 0, u'Items': []}} @@Centory Can you confirm you are following this here? https://github.com/MediaBrowser/Wiki/wiki/Theme-songs-&-videos I will test on my side. I don't think I have one for movies. Edited January 27, 2019 by Angelblue05
Centory 21 Posted January 27, 2019 Author Posted January 27, 2019 Yes, i have my themes sorted like /Movies /Home Alone (1990) homealone.mp4 /theme-music song.mp3 song1.mp3 song2.mp3
K1ng_Lear 240 Posted February 3, 2019 Posted February 3, 2019 Sorry, but can anybody tell me where I can get this TvTunes? I can’t find any working repo.
DarzLir 0 Posted February 5, 2019 Posted February 5, 2019 I subscribe to this topic because today, with the release of the stable version of coreelec, I made a clean installation. I installed the addons of tvtunes and emby and when I synchronizing the themes, even though it tells me that it was done correctly, it does not sound anything. It created the folder "/storage/.kodi/userdata/addon_data/plugin.video.emby/library/" with all library of Emby but only with the nfo attached, no more folders with the name of movies or tv shows. if you need to do any more tests, here I am to try. PS. I have tried putting the "theme.mp3" by hand. but it did not work. tvtunes.nfo
Angelblue05 4132 Posted May 4, 2019 Posted May 4, 2019 I know it's been a while, it fell lower in priority. but it is finally resolved with the next beta version of Emby for Kodi 4.0.17. 2
K1ng_Lear 240 Posted May 5, 2019 Posted May 5, 2019 I know it's been a while, it fell lower in priority. but it is finally resolved with the next beta version of Emby for Kodi 4.0.17. Sorry, that I‘ve to ask again, but where can I get this plugin to play the tunes? I can‘t find a living sources.
Angelblue05 4132 Posted May 5, 2019 Posted May 5, 2019 Sorry, that I‘ve to ask again, but where can I get this plugin to play the tunes? I can‘t find a living sources. I’m not sure I understand your question. Can you try to ask it differently?
loomes 40 Posted May 5, 2019 Posted May 5, 2019 Sorry, that I‘ve to ask again, but where can I get this plugin to play the tunes? I can‘t find a living sources. https://github.com/robwebset/script.tvtunes 1
Angelblue05 4132 Posted May 6, 2019 Posted May 6, 2019 Retry with the new add-on beta version 4.0.17a 2
loomes 40 Posted May 6, 2019 Posted May 6, 2019 I try with 4.0.18, and all is fine. All nfo's are correctly generated 1
