catch42 3 Posted November 30, 2018 Posted November 30, 2018 I am having trouble removing songs from playlists. Using the web client, I can remove the song using the "remove" button on the far right side, but I can't seem to get the changes to save. I select the option to save the modified playlist, then select the same playlist name to overwrite it. But upon reloading the playlist, the removed songs are still there. Thanks in advance for the help.
Solution Luke 42216 Posted November 30, 2018 Solution Posted November 30, 2018 It sounds like you're removing from the now playing queue screen and not the original playlist. Is that correct? 1
catch42 3 Posted November 30, 2018 Author Posted November 30, 2018 It sounds like you're removing from the now playing queue screen and not the original playlist. Is that correct? That's correct. Am I missing the way to modify the playlist directly?
catch42 3 Posted November 30, 2018 Author Posted November 30, 2018 [facepalm] I knew I was missing something simple. I wasn't getting to the playlist detail screen because I was always selecting inside the play circle. Problem solved, thanks.
