Oracle 86 Posted November 29, 2018 Posted November 29, 2018 In the PS4 web browser, when selecting a season, I am unable to individually select an episode of my choosing. For example, "The Flash S01E05", I am play the entire season but not the specific episode. Not sure if I am getting the point across, and am happy to explain further. Is this a bug? What is the fix?
Oracle 86 Posted November 29, 2018 Author Posted November 29, 2018 (edited) Nothing. It essentially just lets you hover over it with the curse, and won't let me select it. It's gotten to the point where I have to stream it from another device to play a specific episode on the PS4. Which is rather annoying after a while. Edited November 29, 2018 by SPRINKLES-PC
Luke 42239 Posted November 29, 2018 Posted November 29, 2018 I just tested this and it seems to be working fine. Are you making sure to put both the focus box as well as the mouse cursor over the episode you want to play?
Oracle 86 Posted November 29, 2018 Author Posted November 29, 2018 (edited) Let me try that. EDIT: I have been doing that, it does not work. Edited November 29, 2018 by SPRINKLES-PC
Luke 42239 Posted November 30, 2018 Posted November 30, 2018 What do you mean does not work? What happened when you tried?
Oracle 86 Posted November 30, 2018 Author Posted November 30, 2018 It won't give me the option to select it, just am able to hover over it.
Luke 42239 Posted December 1, 2018 Posted December 1, 2018 I am not quite sure what to say, as I tested again tonight and still did not have any problems. What i would suggest is using the d-pad arrow keys to highlight the episode you want to play. Then before clicking, then use the stick to make sure the mouse cursor is also over it. Doing this I had no problems.
Oracle 86 Posted December 30, 2018 Author Posted December 30, 2018 (edited) I am not quite sure what to say, as I tested again tonight and still did not have any problems. What i would suggest is using the d-pad arrow keys to highlight the episode you want to play. Then before clicking, then use the stick to make sure the mouse cursor is also over it. Doing this I had no problems. Been playing with this since we last spoke about it. I have no idea either, mate. Edited December 30, 2018 by Arly (Sprinkles)
Oracle 86 Posted January 2, 2019 Author Posted January 2, 2019 (edited) @@Luke Not sure what to do here. Could it be a PS4 setting? Looked into this and nothing seems to fix the issue I also can't find another case of this issue anywhere. Edited January 2, 2019 by Arly (Sprinkles)
Solution Oracle 86 Posted January 2, 2019 Author Solution Posted January 2, 2019 Can you show an image of what you see? Turns out I was using app.emby.media and not tv.emby.media. Well then. I feel like an idiot. This issue is fixed and can be closed.
