kingargyle 19 Posted November 29, 2018 Posted November 29, 2018 I have a couple of MKVs that I created with Handbrake. One with 1.0.3 and another with an older version of Handbrake. Both will direct stream fine from Plex through my Serenity client, but neither will direct stream through the same client but using Emby as the server. Emby is able to Transcode the files and I can get them to play that way. When I direct Stream, I get a 404 returned. I've have several others that do work correctly. Here is the MediaInfo from one of the backups of a dvd I own that does not work. My EmbyServer versions is unfortunately stuck at 3.3.x due to the server it is running on.: General Unique ID : 168834847036156318455275332920746828792 (0x7F0468A440B08334967DCF6AB191E3F8) Complete name : Popeye.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 999 MiB Duration : 1 h 53 min Overall bit rate : 1 225 kb/s Movie name : Popeye Encoded date : UTC 2018-11-29 00:50:22 Writing application : HandBrake 1.0.3 2017030500 Writing library : Lavf57.56.101 / Lavf57.56.101 ErrorDetectionType : Per level 1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Bit rate : 753 kb/s Width : 720 pixels Height : 364 pixels Display aspect ratio : 2.35:1 Original display aspect ratio : 2.35:1 Frame rate mode : Variable Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 148 r2748 97eaef2 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 DURATION : 01:53:58.873000000 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1 h 53 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 365 MiB (37%) Title : Surround Language : English Default : Yes Forced : No DURATION : 01:53:58.336000000 Menu 00:00:00.000 : :Chapter 1 00:10:57.023 : :Chapter 2 00:18:00.454 : :Chapter 3 00:29:27.441 : :Chapter 4 00:36:36.236 : :Chapter 5 00:43:09.295 : :Chapter 6 00:47:53.379 : :Chapter 7 00:57:45.470 : :Chapter 8 01:11:38.469 : :Chapter 9 01:21:31.895 : :Chapter 10 01:33:56.639 : :Chapter 11 01:43:51.734 : :Chapter 12
Luke 42246 Posted November 29, 2018 Posted November 29, 2018 Hi, can you attach the server log? Thanks.
kingargyle 19 Posted November 29, 2018 Author Posted November 29, 2018 Hi, can you attach the server log? Thanks. Yeah, when I get home tonight I'll get you those.
kingargyle 19 Posted November 29, 2018 Author Posted November 29, 2018 Luke, here is the relevant portion of the server log where it wasn't able to Direct Stream the above MKV. 2018-11-28 21:27:58.022 Error HttpServer: Could not find handler for /emby/Videos/e3a6dbaf34f28b776872309e57695796/stream.mkv,webm2018-11-28 21:27:58.022 Info HttpServer: HTTP Response 404 to 192.168.86.113. Time: 1ms. http://192.168.86.93:8096/emby/Videos/e3a6dbaf34f28b776872309e57695796/stream.mkv,webm?static=true 2018-11-28 21:27:58.032 Info HttpServer: HTTP GET http://192.168.86.93:8096/emby/Videos/e3a6dbaf34f28b776872309e57695796/stream.mkv,webm?static=true. User-Agent=SerenityAndroid, Accept-Encoding=identity, Host=192.168.86.93:8096, Connection=Keep-Alive2018-11-28 21:27:58.033 Error HttpServer: Could not find handler for /emby/Videos/e3a6dbaf34f28b776872309e57695796/stream.mkv,webm2018-11-28 21:27:58.033 Info HttpServer: HTTP Response 404 to 192.168.86.113. Time: 1ms. http://192.168.86.93:8096/emby/Videos/e3a6dbaf34f28b776872309e57695796/stream.mkv,webm?static=true Here is a link to the full file as well: https://drive.google.com/file/d/1PnokWGljVm2lAly8r40cd-J9TCXLbzyR/view?usp=sharing
Solution Luke 42246 Posted November 30, 2018 Solution Posted November 30, 2018 Older versions of the server would sometimes return multiple formats in the Container property because this is what ffmpeg reported to us. So that's why your url has an extension: mkv,webm This will not happen anymore with newer versions of the server. If you refresh metadata on that title i think it will be fixed. You can also safe-guard client-side if you wish by splitting the Container property by commas and then using the first value. 1
kingargyle 19 Posted November 30, 2018 Author Posted November 30, 2018 Older versions of the server would sometimes return multiple formats in the Container property because this is what ffmpeg reported to us. So that's why your url has an extension: mkv,webm This will not happen anymore with newer versions of the server. If you refresh metadata on that title i think it will be fixed. You can also safe-guard client-side if you wish by splitting the Container property by commas and then using the first value. Thanks, I'll make a change in my app's mapping so that if the container contains. MKV or MP4, it only uses that format instead of just passing the container property directly.
