Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 can you go here: /var/lib/emby/plugins Then delete the dll files for cover art and statistics and try again? thanks. Removed and my emby-server shutdown again Logs : https://pastebin.com/Eij7V1Fx
Luke 42255 Posted December 9, 2018 Posted December 9, 2018 The plugins are still in the log. It doesn't look like you removed them.
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 The plugins are still in the log. It doesn't look like you removed them. Strange, my new logs -> https://pastebin.com/TtLmvjEa Shutdown again
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 I only have 8 .dll files left, the 3 installed plugins are removed
Genetik57 0 Posted December 9, 2018 Author Posted December 9, 2018 Same thing. Yet everything is deleted I do not understand anything anymore
Luke 42255 Posted December 9, 2018 Posted December 9, 2018 Can you delete all existing log files and try again? Thanks.
Genetik57 0 Posted December 10, 2018 Author Posted December 10, 2018 Can you delete all existing log files and try again? Thanks. Same problem I try with the armhf version I'll keep you informed
leofuscaldi 0 Posted February 5, 2019 Posted February 5, 2019 Same problem I try with the armhf version I'll keep you informed Did the armhf version worked for you? Got a NanoPi m4 board, same chipset and same error (Stackoverflow)
