tietherope 0 Posted November 28, 2018 Posted November 28, 2018 (edited) Hi All, Just set up Emby on my Shield and DS918+ this past weekend. I have several files with TRUEHD 7.1 as the main audio track, but also have Dolby Digital 5.1 and some commentary tracks. The movies will not play because my audio is used through ARC and I understand that will not work, which is fine. However, it does not let me switch to a different audio track. Maybe because the movie never starts playing? I can however go into setting and turn on "Downmix to stereo" and then the film will play. From there I can switch between tracks and if I leave it on Dolby Digital 5.1, I can then go turn off the downmix to stereo and then come back to the movie and switch through tracks as well. However if I pick TRUEHD again, then the movie stops playing and I can't switch audio tracks again. I have attached what I hope is the proper section of the server log. If not, it's my first time with that, so please let me know and I'll get a better one. Hopefully I didn't miss a very obvious place which says this is normal. Thanks for any help or insight you can give. Server Log.txt Edited November 28, 2018 by tietherope
Luke 42245 Posted November 28, 2018 Posted November 28, 2018 Hi, was there an ffmpeg log? Can you please attach that too? Thanks !
tietherope 0 Posted November 28, 2018 Author Posted November 28, 2018 Hey, thanks for the response. The log is attached. It should show me starting on Dolby Digital 5.1, switching to TRUE HD 7.1 and then trying to switch back to DD, but the change not taking effect. Let me know if I'm missing anything. FFMPEG Log.txt
Solution ebr 16337 Posted November 28, 2018 Solution Posted November 28, 2018 Hi. The reason the item is not starting is due to the PGS subs being selected. When we have to transcode due to the audio then those subs have to be burned in, which your server is just not powerful enough to do. If you obtain external text subs for this item, then this problem should go away.
tietherope 0 Posted November 28, 2018 Author Posted November 28, 2018 Thank you so much! Turned subtitles off and it works. I can then watch with it on the TRUE HD track without subs. Or on DD 5.1 with the second English subs selected. Which would be the subs I set up to download through Open Subtitles? Thanks for the impressively quick help!
tietherope 0 Posted December 23, 2018 Author Posted December 23, 2018 (edited) Hi. The reason the item is not starting is due to the PGS subs being selected. When we have to transcode due to the audio then those subs have to be burned in, which your server is just not powerful enough to do. If you obtain external text subs for this item, then this problem should go away. Hi, I just updated to the Synology Beta 3.6.0.80 and have now lost my subs. Any files that are Dolby+ or higher show as direct streaming and when I turn on subs, they do not show up. These are files that watching yesterday on the stable release, I could see the subtitles. Dolby 5.1 files that direct play, instead of direct stream, show the subs. Any way to remedy this? Thanks! Edit: In regards to direct streaming it says the following below when I play Dolby+ files. All the files, whether Dolby 5.1 or Dolby+ are an .mkv So is it an incorrect message and it is direct streaming due to audio? Or is it misreading the container? Direct streaming The media is compatible with the device regarding resolution and media type (H.264, AC3, etc.), but is in an incompatible file container (.mkv, .avi, .wmv, etc.). The video will be re-packaged on the fly before streaming it to the device. Direct Streaming a file uses very little processing power without any loss in video quality. FFMPEG Log2.txt FFMPEG Log3.txt Server Log2.txt Edited December 23, 2018 by tietherope
Luke 42245 Posted December 23, 2018 Posted December 23, 2018 @@tietherope, it doesn't appear you had any subtitles selected. Can you please try selecting them in the video player? Thanks !
tietherope 0 Posted December 23, 2018 Author Posted December 23, 2018 @@tietherope, it doesn't appear you had any subtitles selected. Can you please try selecting them in the video player? Thanks ! Thanks for the response. For those logs I started playing the show, went to subtitles, and selected English. The info showing then changes from CC (Off) to CC (Eng), but subtitles don't actually display. Doing the exact same thing on a Dolby 5.1 file results in the subtitles showing. Here is a new log for the same episode, but selecting the subtitles before I hit play (Android TV Beta). Let me know any other info you may need, FFMPEG Log4.txt
Luke 42245 Posted December 23, 2018 Posted December 23, 2018 Can you attach the emby server log as well? Thanks.
tietherope 0 Posted December 23, 2018 Author Posted December 23, 2018 (edited) Can you attach the emby server log as well? Thanks. I attached one above in post #6, but just made and attached new one where I chose the subtitles before I hit play, in case that shows differently. I have also attached a massive log from yesterday (because I don't know what to cut out) when the subs worked on the stable release. From my uneducated browsing this is what I see that sticks out to me: The log from the beta release there is - 2018-12-23 13:48:06.827 Error SubtitleEncoder: ffmpeg subtitle extraction failed for file:"/volume1/TV/Barry/Season 1/Barry - S01E03 - Chapter Three- Make the Unsafe Choice.mkv" to /var/packages/EmbyServer/target/var/cache/subtitles/7/72fe3b92431305817739c4f1692ddd7f_636706243460000000_2_0_0_False.subrip In the log from the stable release there is - 2018-12-22 13:23:05.454 Info SubtitleEncoder: ffmpeg subtitle extraction completed for file:"/volume1/TV/Barry/Season 1/Barry - S01E03 - Chapter Three- Make the Unsafe Choice.mkv" to /var/packages/EmbyServer/target/var/data/subtitles/6/69c7dadd-6eef-dd2d-b7e2-7a0a2a47e3f1.srt Thanks again! Server Log Synology Beta Subs Not Playing.txt Server Log Synology Stable Subs Working.txt Edited December 23, 2018 by tietherope
Luke 42245 Posted December 24, 2018 Posted December 24, 2018 Ok, please try the next beta server. Thanks.
