jasonwilliams 37 Posted November 27, 2018 Posted November 27, 2018 Hello, I notice there is an option set in the TV Tuner configuration to select the video renderer. The options are "Overlay, VMR7, VMR9, EVR". Does this make a difference to Emby at all, and if so, which should I select? Thanks, Jason
Luke 42244 Posted November 28, 2018 Posted November 28, 2018 That shouldn't matter. I believe that is only for their own WinTV software.
SHSPVR 125 Posted November 28, 2018 Posted November 28, 2018 Hello, I notice there is an option set in the TV Tuner configuration to select the video renderer. The options are "Overlay, VMR7, VMR9, EVR". Does this make a difference to Emby at all, and if so, which should I select? Thanks, Jason Not one bit but for when using WinTV then set to EVR
