makarai 109 Posted November 30, 2018 Posted November 30, 2018 @@tachain. I ask this all the time what freenas version are you using. I hope it's RC-2. The previous ones had a lot of problems with automatic interface creation mounting and so on
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 Hi, questions. Which interface is the cable plugged in? Can you please install another plugin from the plugin catalogue, I recommend irssr. Can you type ifconfig in the shell and report back Hi, 1. My cable plugged into: igb0 2. Manage to install irssr with DHCP 3. ifconfig , see ifconfig.txt Just wondering if the error occurred for installation of 1st plugin, I manage to install zoneminder now as well.
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 @@tachain. I ask this all the time what freenas version are you using. I hope it's RC-2. The previous ones had a lot of problems with automatic interface creation mounting and so on Yes. OS Version: FreeNAS-11.2-RC2 (Build Date: Nov 15, 2018 20:21)
makarai 109 Posted November 30, 2018 Posted November 30, 2018 Hi, 1. My cable plugged into: igb0 2. Manage to install irssr with DHCP 3. ifconfig , see ifconfig.txt Just wondering if the error occurred for installation of 1st plugin, I manage to install zoneminder now as well. And all the plugins that you installed select bridge0 as their interface?
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 And all the plugins that you installed select bridge0 as their interface? Plugin Install sequence and selected interface: 1. Emby - bridge0 2. zoneminder - bridge0 3. irssr - DHCP
makarai 109 Posted November 30, 2018 Posted November 30, 2018 (edited) root@freenas[~]# ifconfig igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:cx hwaddr 0x:cx inet 192.168.0.2 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 0c:c hwaddr 0c:c nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> ether 00:b hwaddr 00:b nd6 options=1<PERFORMNUD> media: Ethernet autoselect status: active groups: tap Opened by PID 3980 bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:e nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0:10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 6 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 vnet0:10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: emby-server-beta56 options=8<VLAN_MTU> ether 02:ff:60:2e:4a:95 hwaddr 02:78:d0:00:06:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair root@freenas[~]# You can see, normally the bridge0 has different members- IGB0 (physical) vnet0 (Jails) tap0(VMs) So i am confused why yours does not. I am asking this because you probably run into problems at somepoint if your network is not properly installed within freenas itself. If i start a second emby server you can even see how this is working it just adds a member to the bridge0 vnet0:34: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: emby-server-beta73 options=8<VLAN_MTU> ether 02:f hwaddr 02:7 nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair Sorry if I ask all the stupid questions: but is the ifconfig output before or after you installed irssr ? Last question do you have any tuneables installed ? (before RC2 you had to put) System > Tunables Variable: cloned_interfaces, Value: bridge0, Type: rc.conf Variable: ifconfig_bridge0, Value: addm vnet0 up, Type: rc.conf in the tunables to get jails running, if you still have them in there take them out and reboot Edited November 30, 2018 by makarai
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 root@freenas[~]# ifconfig igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:cx hwaddr 0x:cx inet 192.168.0.2 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 0c:c hwaddr 0c:c nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> ether 00:b hwaddr 00:b nd6 options=1<PERFORMNUD> media: Ethernet autoselect status: active groups: tap Opened by PID 3980 bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:e nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0:10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 6 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000000 vnet0:10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: emby-server-beta56 options=8<VLAN_MTU> ether 02:ff:60:2e:4a:95 hwaddr 02:78:d0:00:06:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair root@freenas[~]# You can see, normally the bridge0 has different members- IGB0 (physical) vnet0 (Jails) tap0(VMs) So i am confused why yours does not. I am asking this because you probably run into problems at somepoint if your network is not properly installed within freenas itself. If i start a second emby server you can even see how this is working it just adds a member to the bridge0 vnet0:34: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: emby-server-beta73 options=8<VLAN_MTU> ether 02:f hwaddr 02:7 nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair Sorry if I ask all the stupid questions: but is the ifconfig output before or after you installed irssr ? Last question do you have any tuneables installed ? (before RC2 you had to put) System > Tunables Variable: cloned_interfaces, Value: bridge0, Type: rc.conf Variable: ifconfig_bridge0, Value: addm vnet0 up, Type: rc.conf in the tunables to get jails running, if you still have them in there take them out and reboot The ifconfig output before installation of irssr. Is a new server, New Installation, no prior version.
makarai 109 Posted November 30, 2018 Posted November 30, 2018 (edited) The ifconfig output before installation of irssr. Is a new server, New Installation, no prior version. can you post a second ifconfig output after the installation of irssr. Sorry i didnt make that clear, i am hoping that the dhcp installation created the necessary interfaces. i.e. vnet0 honestly just check if there is another interface i.e. vnet0 or similar. Edited November 30, 2018 by makarai
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 can you post a second ifconfig output after the installation of irssr. Sorry i didnt make that clear, i am hoping that the dhcp installation created the necessary interfaces. i.e. vnet0 Here you go. ifconfig.txt
makarai 109 Posted November 30, 2018 Posted November 30, 2018 Here you go. Well, that was uneventful. Unfortunately no new interface was created. This seems weird. I have to get back to you on this one, i am guessing you'll run into problems at some point.
tachain 0 Posted November 30, 2018 Author Posted November 30, 2018 Well, that was uneventful. Unfortunately no new interface was created. This seems weird. I have to get back to you on this one, i am guessing you'll run into problems at some point. I ran into problem... I changed IPv4 manual settings back to DHCP. now I see the vnet0. All good now:) ifconfig.txt
makarai 109 Posted November 30, 2018 Posted November 30, 2018 (edited) AWESOME! now you basically have to change your other jails and plugins and you can use the installation method provided for a solid emby setup cd /tmp wget https://raw.githubusercontent.com/ma-karai/iocage-plugin-emby/beta/emby-server-beta.json iocage fetch -P dhcp=on vnet=on bpf=yes allow_raw_sockets=1 -n emby-server-beta.json --branch 'beta' Edited April 26, 2019 by makarai
